Intake manifold rear coolant passage hose kits - Chevelle Tech
 2Likes
  • 2 Post By Yukon0724
post #1 of 10 (permalink) Old Oct 17th, 18, 3:28 PM Thread Starter
Does anyone have any experience with connecting the intake manifold rear coolant passages to the front coolant crossover/thermostat area? See attached picture for an example. I've heard from a couple individuals at car shows that it can be very effective at improving coolant flow through the heads where the greatest amount of heat is located and therefore could benefit from improved flow.
https://www.thirdgen.org/forums/atta...psb4c55238.jpg
Name:	Rear intake manifold coolant hose picture.jpg
1967 Chevelle Malibu, 463 BB, Edelbrock Performer RPM Power Package, Holley Terminator EFI, TCI Street Fighter 700R4, Moser Muscle Pac 12 bolt rearend, RideTech air suspension system, Accuair e-level air management, Wilwood Forged Dynalite disc brakes, US Mags Rambler wheels & Continental Extreme Contact tires
bbertlin is offline
post #2 of 10 (permalink) Old Oct 17th, 18, 4:31 PM
Jimmy
Re: Intake manifold rear coolant passage hose kits
I did on my Intake.
Yukon0724 is offline
post #3 of 10 (permalink) Old Oct 17th, 18, 4:33 PM
It looks to me like it is reducing the amount of coolant that flows past the combustion chambers. That would make the front cylinders even hotter than usual. The coolant that flows through those hoses does nothing for cooling.
Many years ago, i did some testing of valve seat and combustion chamber temperatures on an inline 6 car engine. The coolant entered the front of the block and flowed to the rear, where is entered the rear of the cylinder head. Then it flows to the front of the head and then out. The rear chambers (and valve seats ) were the coolest and the front cylinders were the hottest. I suspect that reducing the flow would make things worse.
I must be missing something here.
JWagner is online now
post #4 of 10 (permalink) Old Oct 17th, 18, 4:39 PM
Meziere makes a spacer for the water outlet with a couple of tapped holes, just for this purpose.
Steve R
Steve R is offline
post #5 of 10 (permalink) Old Oct 17th, 18, 5:00 PM Thread Starter
Originally Posted by Yukon0724 View Post
I did on my Intake.
Why did you do this mod/what was the problem you were trying to solve?
What were your results?
Thanks.
bbertlin is offline
post #6 of 10 (permalink) Old Oct 18th, 18, 4:15 AM
I have them on my engine and I can't really comment as to whether they have a positive or negative affect.........because I'm not disconnecting them to find out
I'm lucky enough to be able to keep an 800hp BBC cool on the street with a pair of 12" spals, a 32" rad and this tubing, so I'll be leaving the tubes in place......for the time being
rodent4 is offline
post #7 of 10 (permalink) Old Oct 18th, 18, 4:35 AM
Jimmy
Thanks.
I wasn't trying to solve any problem. Just prevent any from happening. Setups like this are quite popular at my local tracks. Oval and Drag Strip tracks. With a twin turbocharged SmBlk Detonation is the Engines biggest enemy and eliminating hot spots in the cooling system helps prevent that. I can't really comment on if they help or not has they have been on the manifold since I first built the Engine. The Edelbrock Super Victor Manifold comes with the front and rear ports already drilled and tapped so why not use them.
post #8 of 10 (permalink) Old Oct 18th, 18, 4:37 AM
Jimmy
Nice looking Engine Bay you have there Jim.
post #9 of 10 (permalink) Old Oct 18th, 18, 1:23 PM Thread Starter
Thanks for the information and pics. The feedback is similar from what I've heard from others about connecting the rear water passages to the front.
bbertlin is offline
post #10 of 10 (permalink) Old Oct 20th, 18, 4:35 PM
Ron
You have excellent taste in selecting the color of your car..
My car is here:
bikeron is online now
This Thread is more than 451 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
