Thoughts on Mechanical Fan Please - Page 4 - Chevelle Tech
 37Likes
post #46 of 51 (permalink) Old Jun 10th, 19, 1:26 PM
Greg.
Re: Thoughts on Mechanical Fan Please
Originally Posted by paul bell View Post
I'm running a pair of these 1990's Toyota Camry V6 fans on a dual fan shroud. They move a ton of air and I think it's because of the wide blades. Enough air that they keep my 496 600 hp big block cool almost always at half speed.
Paul any Part #s for the EFans and Dual Shroud ??
A Pic of the Setup in your Car would be nice to !
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.561
1/8 = 7.411 et / 90.18 mph
1/4 = ??.??? et / ??? mph
Kirk's67SS is online now
post #47 of 51 (permalink) Old Jun 10th, 19, 10:18 PM
Back in the days when I would hang out at my friendís bodyshop after work every day, his wife had a V6 Camry wagon and we were fixing the AC. When it came on, this fan moved a ton of air. I bought two at a parts store.
Also kicking around the shop was a Nissan of some kind and I discovered the fan shroud fit our big old radiators pretty nicely. As I recall, I had the round discs made to adapt the fans to the shroud. Itís how we did things back then when the aftermarket was pretty thin.
All worked well and I still use it today, half speed for low and full speed for high, triggered by the Fitech LS ECM. Each fan draws just over 20 amps at full speed.
The Toyota fan is from a 1988~1992 Camry 2.5 V6 car, it looks to be part number TO3113101.
The Nissan shroud is anybodies guess, I have no clue.
My point was that in my experience, fans with wide blades seem to move a lot of air. I also know big amperage draw = big CFM. How much CFM are my fans? I have no clue but they do the job.
If I needed this today, the aftermarket is flush with options, Iíd look for a shroud that completely covers the radiator, holds the largest fans possible and then choose fans that fit and have the highest CFM flow. I know this would be at least $400.00. I'm a frugal man (read: not loaded) and what I have works so I see no need to change it.
Name:	FANS close.jpg
LeoP, boyd66k20 and Kirk's67SS like this.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #48 of 51 (permalink) Old Jun 10th, 19, 10:34 PM
I can't believe I found it. 1990 Nissan Maxima fan shroud.
Name:	1990 Maxima shroud.JPG
LeoP and Kirk's67SS like this.
How may I help you?
1999 Trans Am-500hp
post #49 of 51 (permalink) Old Jun 11th, 19, 7:57 AM
Which part is Toyota, the blades, or the blades and motor?
I would love to find something Chevy, or GM instead of an import (or even Ford/Chrysler), if I went that route, but I bet that works very well.
Pioneer4x4 is offline
post #50 of 51 (permalink) Old Jun 11th, 19, 8:35 AM
The Toyota fan comes with everything in post 45, motor, blade and little steel shroud.
How may I help you?
1999 Trans Am-500hp
post #51 of 51 (permalink) Old Jun 11th, 19, 2:46 PM
Anyone tried something like this? For those that have to have something of an American brand maybe this could work?
https://www.discountbodyparts.com/ca...MI2w&gclsrc=ds
Getting ready to get the old bucket of bolts back on the road down here in HOTlanta and started thinking this subject over yet again. I know I MUST MUST MUST have something that can get the job done at low vehicle speeds and there is no way I am going to sit there keeping the engine RPM high with the gas pedal. Traffic is impossible here and getting worse every week if that is possible.
My 4Runner has a clutch fan, I can sit in traffic all day with the A/C on and nothing happens to the temp ...nice and soild at the same indicated temp it runs at on the highway or around town when there is no traffic (which is almost never). My wife's Lexus has electric fans and like the clutch fan 4Runner it has no issue sitting around in traffic.
oman is offline
