Oveheating or NOT??? - Chevelle Tech
 24Likes
post #1 of 41 (permalink) Old Jun 26th, 18, 7:51 AM Thread Starter
Ok, here goes.
I have a 1970 Chevelle SS. In it I have a 454. I just installed a Cold Case Radiator with the 2 Fan/Shroud setup. I also installed the 190 degree thermal switch for the fans that came with this system. I also have a Dakota Digital gauge setup. I installed a 180 degree thermostat. My question is as follows.
My temperature gauge will read between 200-210 and then the fans come on. I thought maybe I had a bad temperature sensor, so I ordered a new one from Dakota digital, installed it and I'm still getting the same readings. When driving the highway my temp stays around 200-205. The temp sensor is in the drivers side head. What's going on here??
Groundhogjr is offline
post #2 of 41 (permalink) Old Jun 26th, 18, 8:47 AM
Re: Oveheating or NOT???
Hmmm..........Philip is having a similar problem in his wagon. Check with him.
66 Malibu
busterwivell is offline
post #3 of 41 (permalink) Old Jun 26th, 18, 8:59 AM
If the thermoswitch is supose to turn the fans on at 190, and the fans don't kick on till 210, I'm guessing that may be the culprit.
Do you run antifreeze? Timing and jetting also can play a role as well as a simple radiator cap.
Sent from my SM-G930V using Tapatalk
frank1911 is offline
post #4 of 41 (permalink) Old Jun 26th, 18, 8:59 AM Thread Starter
Who's Phillip and where is he located?
post #5 of 41 (permalink) Old Jun 26th, 18, 9:03 AM Thread Starter
More info. The switch is located by the Thermostat housing. When I use a heat gun to check temps, the temp by the housing is 20 degrees less than by the sensor in the head. Why and how is it 20 degrees less in that short of span?
post #6 of 41 (permalink) Old Jun 26th, 18, 10:14 AM
Get a meat thermometer, open rad cap, lay it in there and start it up and let it get hot. See what the other thermometer says. And in the kitchen, boil some water and see what it says, that way you will know if it is correct.
blm and fr8dog like this.
Pioneer4x4 is offline
post #7 of 41 (permalink) Old Jun 26th, 18, 2:25 PM
Measuring temperatures in heads, will always be hotter than intake etc. your gauge reads the heads temp, and your switch is operating from intake temps, unless I misunderstood what you’re describing.
Seems like you are good to go.
yanniziomas is online now
post #8 of 41 (permalink) Old Jun 26th, 18, 3:16 PM
Marcus
Like yanniziomas said its because of the temp difference between the heads and thermostat housing. I have two temp gauges one in the head and one in the intake and my gauges also differ 20 deg. Its because of the heat from the combustion.
One solution is to change the fan switch to one with lower temp like 180-185 or a 160 deg thermostat and a 165-175 deg switch. 210 in the head is on the edge imho.
Kirk's67SS likes this.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is online now
post #9 of 41 (permalink) Old Jun 26th, 18, 3:20 PM
Originally Posted by Groundhogjr View Post
Ok, here goes.
Try putting the fan switch sending unit on the head, then place your temp gauge sending unit in the intake and see what happens.
Video:
fr8dog is offline
post #10 of 41 (permalink) Old Jun 26th, 18, 5:43 PM Thread Starter
I've had this problem for a while. Every time I talk with other car guys, they say "Oh my car runs all day at 180/185, no problem". Now not to be a smart ass, but come on not every body is telling the truth.
post #11 of 41 (permalink) Old Jun 26th, 18, 5:50 PM Thread Starter
Right now I'm running a Fail-Safe 180 degree thermostat. Would I be better off going to a High Flow 160 or 180 Thermostat?
post #12 of 41 (permalink) Old Jun 26th, 18, 6:55 PM
Marcus
Ask them if ots in head pr intake if on intake they run same temp as you, with a 180 deg thermostat the head temps is atleast 200 in my experience.
With a 160 deg thermostat my temp is 175-180 deg in the head.
I like and have had good luck with milodon high flow thermostats.
post #13 of 41 (permalink) Old Jun 26th, 18, 8:32 PM
Using one of these thermostats
https://www.summitracing.com/parts/m...make/chevrolet
in my ElCamino,and yes it runs 180-190 all day long. No BSing. One thing about electric fans is that they usually aren't needed at highway speeds (on OE's at least) where the airflow through the rads is usually enough to cool the engine.If the highway airflow gets blocked by the elec fan shrouding it can in effect become a sort of an air dam when on the highway.To combat this most OE elec fan shrouds have multiple small reliefs somewhere on them to allow the air to pass through them when the fan is not running.
I don't know if this is your problem but it is something to consider if you're overheating is at speed.
Kirk's67SS and Thor454 like this.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is online now
post #14 of 41 (permalink) Old Jun 26th, 18, 9:35 PM
Depends on where you measure it.
I have a 180 thermostat and my temp sending unit is in the intake. It reads 180-185 all day long.
I bet if I put the temp sending unit in the head it would be 200 or more. But I've never had an overheating problem - that's just where it runs.
Maybe I should move down to a 160 thermostat to lower the head temps? But it seems to run very well where it is...
lucifershammer is offline
post #15 of 41 (permalink) Old Jun 27th, 18, 12:28 AM
Greg.
Ok, here goes.
The Cold Case Shroud is Metal and does not have any Flaps in it for the Hwy
https://www.coldcaseradiators.com/ch...m-radiator-mt/
IMHO
1. the Metal Heats up and therefore retains more heat within the Unit
2. since there are NO Flaps in it for them to open up on the Hwy Speeds the Flow of Air is Restricted
to only able to go thru the Fans area thus less Air Flow to Cool the Rad Fins
this Pic of the SPAL Dual 11" Efans/Shroud in my car shows
the 6 on Top and 6 at Bottom that open on the Hwy & are Closed in Town
The Temp in the Heads is always Higher than the Intake because of the Heat Soak from them
A 160* Thermostat is what I run in my BBC so that it is Fully Open by 180*
as a 180* Thermostat does not Fully Open up until 200*
My 170* Temp Sender for the Efans is in the Intake
And my car Temp will run from 170* to 180* on the Hwy and in Town
at the Track after back to back runs sometimes 190* .
71350SS likes this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
This Thread is more than 633 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
