Need Help w Overheating 327 '66 - Chevelle Tech
 12Likes
post #1 of 66 (permalink) Old May 2nd, 18, 7:32 AM Thread Starter
My recently rescued '66 that has been sitting in a barn for 20 years is coming along nicely. However, I'm having a problem with overheating. I can't run it for more than 10 minutes and it starts banging, clanging, and hoses will pulse. The coolant has been flushed several times after I pulled a lot of crap out of the motor, including a renegade lock washer. It currently has a bottle of Blue Devil coolant flush in it that will get drained tonight after a couple of days of running. I have no temperature gauge on the dash but my infrared shows normal readings everywhere. Except the top of the block, where after 10 minutes it starts getting hot.
I need your help.
What do I try next? Radiator? Water pump? Pull the engine apart?
1966 Malibu 327 200-4r
brockmub is offline
post #2 of 66 (permalink) Old May 2nd, 18, 8:40 AM
Re: Need Help w Overheating 327 '66
Any recent work on the top of the engine? Gasket change?
Sent from my SAMSUNG-SM-N900A using Tapatalk
B52bombardier1 is online now
post #3 of 66 (permalink) Old May 2nd, 18, 8:48 AM
First thing, is it circulating coolant through the rad? I'd pull the thermostat and run without a cap keeping the rad full as it warms up. If it is boiling in the block, and flowing through the rad, something must be blocked somewhere.
I looked back at your thread and that picture of the crud in the intake looks funky. Maybe flush/fill/clean many times.
Pioneer4x4 is offline
post #4 of 66 (permalink) Old May 2nd, 18, 9:58 AM Thread Starter
I did not open up the engine other than to replace the valve cover, carb, and thermostat gaskets. Should also mention that I replaced the thermostat and radiator cap. Placed the overflow tube into a large plastic bottle so it stops puking all over my floor.
Yes the crud was horrible inside the intake initially. Now that I've run it a while it's perfectly clean, so I know that fluid is moving past that point.
Heater hoses get hot with the car and the heater in the car could fry an egg. So water is moving through there. Which points me back to a blocked passage in the block some where. I really don't want to pull the motor apart yet. I'll keep flushing with water and maybe some additional additives.
brockmub is offline
post #5 of 66 (permalink) Old May 2nd, 18, 10:30 AM
jeff
How old is the radiator?
I had a rebuilt radiator in my delta 88.. kept the 350 olds cool.
Stuck that radiator into my 78 Nova and my .060" over 350 ran hot 210 F..I tried all kinds of fans and thermostats and coolants and shrouds.
That rebuilt radiator began leaking on a tank top..I decided to get a NEW radiator they were 94 bucks.
Guess what.. she ran 140 F I had to remove the 2 electric pushers and stick on a shallow pitch fan to get it to 160.
I do not even mess with "rebuilt" radiators any more .
You must have some of the fan blades on the outside of the shroud..as you probably know.
That is if you run a shroud.
If it is sitting idle for 10 minutes this may also be the issue.. get it on the road.
Some cars need air pushing on the radiator.. maybe a fan in front of it.
In all honesty though my stuff can sit all day idling without getting past 195.
Knock on wood.
jeff swisher is offline
post #6 of 66 (permalink) Old May 2nd, 18, 11:26 AM
Drill an 1/8 hole in the thermostat. It will allow any air trapped under the thermostat to bleed out.
Instructions...All I need is the exploded view.
Enganeer is offline
post #7 of 66 (permalink) Old May 2nd, 18, 11:45 AM Thread Starter
Thanks for the reminder about that tip. I had heard it before and then forgotten it. It's a good thing that the thermostat gaskets are a buck because I've gone through a ton of them.
Tonight I'll drain the water and Blue Devil, then drilling a little hole in the thermostat. Might also see what other additives are out there to hopefully find the blocked passage.
brockmub is offline
post #8 of 66 (permalink) Old May 2nd, 18, 12:35 PM
Remove the block drain plugs on each side of the block and flush with water. I tried attaching a photo of these plugs, but it would not upload.
Billrv7 is offline
post #9 of 66 (permalink) Old May 2nd, 18, 12:40 PM
Find an old bottle of DuPont radiator HD radiator cleaner that used caustic soda. Nasty stuff but will clean all that scum and scale. I would use the old radiator for the flush cycles and once all clean, drop in a new radiator, maybe even run a screen in the upper hose to catch debris before it would plug up a new radiator. I believe the DuPont had a small neutralizer agent that came as a separate compartment in the can.
Video:
fr8dog is offline
post #10 of 66 (permalink) Old May 2nd, 18, 7:56 PM
Look at that picture...what do you suppose the inside of the cooling tubes in the radiator look like. As has been mentioned, don't waste your time with an old radiator. You cannot effectively "flush" a radiator at home. For a hundred bucks or so, you can have new one. Drill a hole in the thermostat? Is there something that the engine and thermostat designers and engineers don't know? No thermostat that I know of will make an airtight or watertight seal with the thermostat housing anyway.
JJ'65 is offline
post #11 of 66 (permalink) Old May 2nd, 18, 10:41 PM
Justin
Pop out the drain plugs on the side, remove the hose to the top of the radiator and plug your house into the bottom water pump Inlet. Fire up the engine and turn on the hose and flush that bad boy out. Water will gush out of that thing and clean it it out, might have to bring up the rpm to get it really flowing
JF74chevelle is offline
post #12 of 66 (permalink) Old May 3rd, 18, 8:23 AM
Rich
These are all the evidence you need to signify you need to pull the engine apart. You have probably already damaged it. Put in a new radiator before you run it again.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #13 of 66 (permalink) Old May 3rd, 18, 11:28 AM Thread Starter
If I didn't trust a 50 year old gas tank, why would I trust a 50 year old radiator? That is a legitimate concern. It is a little bit lower on the priority list but a definite possibility to the eventual solution. I actually thought that I was going to need to replace the radiator because the brass drain plug on the bottom was all messed up. It severely mangled and being brass it was easy to make even worse. So I gave up trying to make it drain and just pulled it.
The new brass drain plug will go in tonight and the Chevelle will go up on the ramps to see if I can get access to the rear drain plugs. I'll try another round of water and flush additive.
The thermostat is going to come out before I drill a hole. Two mechanic friends gave conflicting advice about drilling. Though they both agreed that the symptoms the car is having do not seem like air is trapped but more like it could be a blockage.
brockmub is offline
post #14 of 66 (permalink) Old May 8th, 18, 10:36 PM Thread Starter
Replaced the brass plug for easier draining, actually popping the bottom hose into a bucket is pretty easy and quick. Flushed two more times, but it's still overheating after about 6 minutes of idle time. When it drains, I analyze the bottom of the bucket as I pour it into a container for transport. There are some flecks of corrosion but nothing big or like I've pictured previously. The past two flushes have been with water, Blue Devil, and no thermostat. I've opened the cap while its still cold and observed the water flowing past the opening and no obvious bubbling like maybe a bad head gasket would show.
Called Champion today and purchased a AE289 2 Row - 1" tube aluminum radiator. It was cheaper directly from them instead of Eckler's or Jeg's. I've heard a mixed bag of reviews on them but thought it was the next least invasive step to getting the car on the road. Saturday we should have it and hopefully it fits as well as takes care of the problem.
AE289
Once I know the radiator fits and is functioning, I'm debating if I should cut up the old original to see if there are in fact blockages. Any thoughts if I should cut up the old radiator?
brockmub is offline
post #15 of 66 (permalink) Old May 8th, 18, 11:33 PM
don't forget to buy a anode for your new aluminum radiator and add a ground wire from the rad to the core support. I know the water is a ground etc, but some of these rats come with a wire in the box and it only takes a minute. jim
Jim Mac is online now
This Thread is more than 660 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
