Chevelle Tech - View Single Post - 1970 Chevelle Pro Touring on a High School Student Budget
post #3 of (permalink) Old Mar 5th, 11, 9:29 PM Thread Starter
dlabooda
David
Re: 1970 Chevelle Pro Touring on a High School Student Budget
I then towed the frame back up to the the barn where I was storing the body of the Chevelle and reattached it. Then I towed it back down to the garage and started the working on the sheet metal.
This week I bought a gas tank for a 92-96 Caprice and started test fitting it. I only required the frame rails to be ground down a little bit at each corner. I also finished chopping out the rest of the trunk floor. I plan on building my own frame braces and reusing the gas tank braces. Then I will build the trunk floor out of sheet metal with an access door to the fuel sending unit of the gas tank.
So that is all of my progress so far. I just bought a 6.0 Vortec engine out of a 2001 Silverado on ebay and it should be here on Tuesday. I plan on finishing up the bottom sheet metal so that I can take the body back off of the frame to paint it, then start working on the drivetrain.
David
6.0 LQ4, T56, Wilwood brakes, Ridetech Coilovers, Strange 9 Inch
2004 Silverado 2500HD LLY/ZF6
dlabooda is offline
