Vent window weatherstrip - Page 2 - Chevelle Tech
2001 General Tech questions from 2001
post #16 of 20 (permalink) Old Jul 3rd, 01, 12:00 PM
On my 64, the top "hinge" is riveted directly to the vent window frame, thus the rivets had to be drilled out. Sounds from rusty66 above like newer models have screws not rivets.
Getting my gasket into the "V" at the front of the frame (toward front of car) was nearly impossible without a little lube.
Make it the way you like it, forget what the other guys say!
https://www.chevelles.com/showroom/al's64elky-1
https://www.chevelles.com/showroom/al's64elky-2
283v8 is offline
post #17 of 20 (permalink) Old Jul 3rd, 01, 10:34 PM
Rob
283v8. I am not quite sure I read this right, but my top hinge is welded to the window frame. The rivets I had to remove are used to hold the lowest rail. This had to go before I could remove the vent window.
Rob
rusty66 is offline
post #18 of 20 (permalink) Old Jul 13th, 10, 9:59 PM
Mark
Re: Vent window weatherstrip
Mark,
Not to be a pain but if you could foward that article to my email [email protected] I would appreciate it. I am in the process of replacing my vent weatherstrippng only. I have the Body by Fisher manual for my 67 Chevelle 4 door sedan, A body type, but it only shows how to remove the vent not how to remove and reinstall the weatherstipping. It also mentions some kind of adhesive. Is there a special one to use? I have a can of Permatex adhesive. Would that work?
I appreciate the input.
Mark
Mark
mpdsal is offline
post #19 of 20 (permalink) Old Jul 13th, 10, 10:33 PM
Mark you probably won't get any reply as this post was from 2001
Try starting a new post in the Body Shop forum.
1968 is offline
post #20 of 20 (permalink) Old Jul 14th, 10, 5:32 PM
Mark
How embarassing. I didn't see that. Thanks
Mark
mpdsal is offline
This Thread is more than 3329 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
