Replacement A/C hoses? - Chevelle Tech
2001 General Tech questions from 2001
post #1 of 3 (permalink) Old Jun 16th, 01, 6:46 AM Thread Starter
dude67=John C.
Ok, guys I'm looking for replacement A/C bulk hose for my 67'. Where can you get this stuff anymore? 1/2 and 5/8 about 7 ft.
Thanks In Advance!
John Corbin Member #313
67' Chevelle Malibu(Someday), NOT I will have a funeral for the Mailbu as a organ donor for my new 67SS396!!!!!!
Deltona, Florida
E-mail anytime,If I can help I will do my very best!
dude67 is offline
post #2 of 3 (permalink) Old Jun 16th, 01, 8:14 AM
Yes, you can still get the stuff.
First off, you will have to know if you are going to use the original R12 or R134 refrigerant. The hose is different. If you are changing the system, you may also need the ends that are for 134.
When I did my Vintage Air installation, I had to have the hoses made up (due to having different routing of the hoses than what Vintage Air "standard" set-up.
The best way to find a shop that has the stuff in bulk is to locate a shop that does aftermarket installations. You could ask around the factory dealerships (like a Jeep dealer) where they have non-factory units installed. You could also ask around at the RV shops.
At the same time, you should also ask if they can do the crimping of the end units. This is something that you can't do yourself!
The shop that I found could order all sorts of fittings but didn't have much in stock. The reason I say this is that you should count on having to order the "correct" fittings and wait a week for them to come in.
Wes. Vann
Technical Reference section
Gold Member #5
Wes V is offline
post #3 of 3 (permalink) Old Aug 19th, 07, 9:21 AM Thread Starter
dude67=John C.
Re: Replacement A/C hoses?
I found a website for bulk hose with diagrams of the hoses the sell.
http://www.ackits.com/merchant.mvc?S...y_Code=Barrier
67SS396 [=OO===SS===OO=] Limit all US politicians to two terms. One in office, One in prison.
dude67 is offline
This Thread is more than 4569 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
