Electric radiator fans won't come on - Chevelle Tech
 12Likes
post #1 of 45 (permalink) Old Aug 15th, 17, 1:06 PM Thread Starter
Ethan
I bought the dreaded eBay slim fans to try them out and plan on using them for right now. Can't afford anything else right now. I also bought a relay kit on eBay as well. I wired it up like this. 16g brown wire from relay goes to 12v ignition source, 12g red wire goes to auxilliary side of the breaker, 16g black wire goes to temperature switch and the other 12g red wire goes to fans. And a 12g red wire from batt. side of breaker to pos. side of battery.
The slim fans right now are wired up 18g blue to ground and 18g spliced together to 12g red wire butt connector. I have done it vice-versa, too. 18g black to ground and 18g blue to power 12g red wire. Nothing. What am I doing wrong here?
Also, I had to use galvanized fitting for the temperature switch from the radiator, because I didn't have the proper 1/8"NPTM x 3/8"NPTF fitting at the time. Could the temperature switch not be grounding?
Please help! Do you need any photos?
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #2 of 45 (permalink) Old Aug 15th, 17, 1:15 PM Thread Starter
Ethan
Re: Electric radiator fans won't come on
Don't mind the wiring mess. As soon as I can figure out what is going on, I can tidy everything up.
And it's a 60amp relay as well. These fans will probably pull no more than 8-10amps combined.
ID:	466457   Click image for larger version
ID:	466465   Click image for larger version
ID:	466473   Click image for larger version
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #3 of 45 (permalink) Old Aug 15th, 17, 1:24 PM Thread Starter
Ethan
And I get my engine temp up to 210*. No hotter and they still don't come on. I believe the temp switch makes the fans come on at 185* or 200*.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #4 of 45 (permalink) Old Aug 15th, 17, 1:54 PM
It is hard to check your wiring from the pics but if you suspect the temperature switch, just pull the wire off of it and ground the wire to turn on the relay and fans.
69SS454 is offline
post #5 of 45 (permalink) Old Aug 15th, 17, 2:12 PM Thread Starter
Ethan
Well, I just tried that and still nothing.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #6 of 45 (permalink) Old Aug 15th, 17, 2:16 PM
I just tried to post a wiring diagram but I can't get it to work. Just search: 'fan wiring diagram' on the internet. You may not have the relay wired right. Do you have a test light to troubleshoot with?
69SS454 is offline
post #7 of 45 (permalink) Old Aug 15th, 17, 3:02 PM
That picture of the relay looks questionable...
The socket portion is plugged in backwards (as it appears).
Typical stuff is made so the hold down screw is on the opposite side. The mounting tab would be on the same side as the mounting tab on the relay itself.
The socket is actually designed for plug in relays with no mounting tab.
Now, in case it is just Chinese-awesomeness manufacturing, pull the relay, and get a jumper wire and short the two big red wires together at the socket. Fans should start up if there are no other issues with wiring.
Coppertop is offline
post #8 of 45 (permalink) Old Aug 15th, 17, 3:03 PM Thread Starter
Ethan
Yes, I do.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #9 of 45 (permalink) Old Aug 15th, 17, 3:13 PM
Lol, just the relay?
Why don't you contact the manufacturer for support?
*Jeff*
LQ4 / T56 Swap
Hotwire is online now
post #10 of 45 (permalink) Old Aug 15th, 17, 3:21 PM Thread Starter
Ethan
Joe, the plug only goes in one way on this one. I'll try jumping it.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #11 of 45 (permalink) Old Aug 15th, 17, 3:32 PM Thread Starter
Ethan
Hey now, don't make fun of me. I am trying. I am a novice.
Manufacturer probably speaks Indian or Chinese.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #12 of 45 (permalink) Old Aug 15th, 17, 3:46 PM Thread Starter
Ethan
Well, I jumped the two 18g black wires with a 12g wire directly to battery and sure enough, fans came ON. So, what does that tell me? I bad ground? A bad temperature switch?
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #13 of 45 (permalink) Old Aug 15th, 17, 3:50 PM
Next, put the relay back in, and check for 12+ on one side and ground the other on the relay signal wires. If the fans don't run, does the relay even click?
Pioneer4x4 is offline
post #14 of 45 (permalink) Old Aug 15th, 17, 3:50 PM
Bart
Now that you know the fans work, the next step it to get them to work with the relay in place.. Don't worry about the temp sensor just yet, take it one step at a time and you will find out if you have a relay problem or a temp switch issue.
For now, make sure you have your relay wired correctly. I am assuming you have an 87A relay and not a 87.. Tell us which wires you have where using the terminal numbers here...
Bart_Swisher is online now
post #15 of 45 (permalink) Old Aug 15th, 17, 4:14 PM Thread Starter
Ethan
Yes, I have an 87A relay. 30 goes to the battery, 86 goes to the temperature switch, 85 goes to 12v ignition source and 87 goes to fans. 87A is closed.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
This Thread is more than 884 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
