Wiring Novice Question - Chevelle Tech
 6Likes
  • 1 Post By Dean
  • 1 Post By Jim Streib
  • 3 Post By oldcutlass
  • 1 Post By Dean
post #1 of 7 (permalink) Old Jul 30th, 17, 12:53 PM Thread Starter
Ethan
Can I take three wires and twist them together and solder them into one larger gauge wire? I have three Cobalt Digital Autometer gauges (Voltmeter, Water Temp., and Oil Press.) and they require you to tap into the white dash wire. I guess it's supposed to be for lighting. Thanks! Ethan
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #2 of 7 (permalink) Old Jul 30th, 17, 2:09 PM
Re: Wiring Novice Question
Yes and it doesn't need to be a large gauge wire for lights in three gauges.
Wire to dash lights is grey, not white.
Ethan1 likes this.
post #3 of 7 (permalink) Old Jul 30th, 17, 2:20 PM
You can certainly do it that way (star connection) or run the last terminal to the same next one on the neighboring gauge and so on to the third one working your way back to the supply of power (daisy chain).
If you are able to put your own wires to a terminal stud on the gauge, run the proper size wire for what the circuit will be fused at. You don't want to run something like an 18 gauge wire and then fuse that wire at 20A.
robpp likes this.
Always working on something:
Jim Streib is offline
post #4 of 7 (permalink) Old Jul 30th, 17, 4:21 PM Thread Starter
Ethan
Thanks, Dean and Jim! Will do.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #5 of 7 (permalink) Old Jul 30th, 17, 7:41 PM
Use heat shrink tube, not tape.
blm, Ethan1 and Greg P like this.
oldcutlass is online now
post #6 of 7 (permalink) Old Jul 30th, 17, 9:26 PM
In this case I don't think you'll need to worry about the 4 amp dash light fuse being too big for the wire but that is something to always think about.
Ethan1 likes this.
post #7 of 7 (permalink) Old Jul 31st, 17, 4:14 PM Thread Starter
Ethan
Thanks, Dean.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
This Thread is more than 1079 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
