Any pics of Mounted Autometer Electric Oil Pressure Sender - Chevelle Tech
 3Likes
  • 2 Post By 70CHEVELLE396
  • 1 Post By Skier_Bob
post #1 of 13 (permalink) Old Jul 18th, 17, 9:37 AM Thread Starter
Can't get my mechanical oil pressure gauge tube to stop leaking at the gauge. Exploring the switch to electrical......heard and saw the size of the dang sender and the requirement to mount it somewhere else. Does anyone have any pics of a nicely mounted electric oil pressure sending unit?
Thanks.
Skier_Bob is offline
post #2 of 13 (permalink) Old Jul 18th, 17, 10:18 AM
Re: Any pics of Mounted Autometer Electric Oil Pressure Sender
From the engine to the gauge inside I use the woven stainless oil gauge tube. Comes in lengths of 36"--46"--& other lengths. It is about 1/4" dia. with pipe threads on both ends. Threads directly to the oil press. gauge, No other fittings needed, Its made for Mech. oil press. gauges. Snuger down with two wrenches and its good.
Using S. Warner gauges in both 70s. No leaks 18 years and the other one no leaks for 9 years
Will cost around 20-30 Bucks, And its " Forever "!
Robinls5 is offline
post #3 of 13 (permalink) Old Jul 18th, 17, 10:31 AM
Bart
Thanks.
Are we talking small block or big block? On my BB I have an Classic Instruments electric sending unit on mine. I used the front oil galley by the #1 cylinder. It has a short 1.5" straight pipe coming out of the block then a 45 to the sender. Hides nicely behind the power steering pump/gear and header. You don't really even notice it.
Bart_Swisher is offline
post #4 of 13 (permalink) Old Jul 18th, 17, 11:23 AM
Pat
I have a small block and it sits right below the dist. no real issues I can remember other than maybe having to install with dist removed. I don't really remember the install order since so many things have been in and out and changed as the process moved forward.
myrusty66 is offline
post #5 of 13 (permalink) Old Jul 18th, 17, 3:08 PM
Hey Bart:
Thats the same place I run my woven stainless from. On my 70 LS-5 El Camino then I stuck it in the frame and brought it out near the clutch linkage so it can not be seen and then inside. ( show car thing) on my driver I just used a " T " at the back of the block and ran it from the " T " to the dash. On my 70 driver I use the " RED LIGHT " and a Mech. gauge.
Robinls5 is offline
post #6 of 13 (permalink) Old Jul 18th, 17, 3:21 PM
I purchased a kit specially for this. It had two fittings to point sender away from the distributor. You can see the two fittings in the pic. I can install the set up, and remove it, with Dist. in place. I am not used to the mechanical gauges and will only use electrical water and oil pressure gauges and senders.
JohnnySS is offline
post #7 of 13 (permalink) Old Jul 18th, 17, 6:58 PM
Here ya go.....look behind the m/c.
Not an autometer sender, but you get the idea.
Bracket is 1/2" plate aluminum, designed and fabbed by yours truly.
Held on to the firewall by screws through the cowl area.
ID:	460322   Click image for larger version
ID:	460330   Click image for larger version
SSJohn is offline
post #8 of 13 (permalink) Old Jul 18th, 17, 10:52 PM
FWIW I ran my mech oil press gauge for years without a leak. Used stainless braided motorcycle brake line and a couple an to npt adapter fittings. You can buy them in different lengths and are pre made. Goodridge was the brand I used. I've since switched to a Dakota VHX gauge system, so I'm no longer using it. Had it on my Autometer Pro Comp.
HKalin and Skier_Bob like this.
70CHEVELLE396 is offline
post #9 of 13 (permalink) Old Jul 19th, 17, 2:25 PM Thread Starter
All - thank you for responding to request with fantastic info. I have a big block. Why does that dang sender have to be so big. I may try the motorcycle brake line Dave. Will get under the car and see exactly how much clearance I have or not by the filter/headers.
To all - Thanks again for the help
70CHEVELLE396 likes this.
post #10 of 13 (permalink) Old Jul 19th, 17, 2:30 PM
Bart
If you run it from the front oil galley like Bob and I did, you wont need any brake line or anything, just the fitting in the block, a 45 fem-fem and the sender. Mine clears everything perfectly, frame/steering/headers etc. Unless you are looking for it, you don't even see it. Mine is basically exactly like the pic JohnnySS posted only between the motor mount and timing cover.
post #11 of 13 (permalink) Old Jul 19th, 17, 4:22 PM
Bob-I installed the Autometer 3-guage all electric mini guages on my 1970 big block with stock exhaust manifolds.I installed the autometer sender and stock idiot switch at the oil filter.It was very tight but it all fit.
Scott 1970 SS 396 is offline
post #12 of 13 (permalink) Old Jul 19th, 17, 4:43 PM
AKA Zombietroll
Last time I had a mechanical oil gauge leak at the fitting it was actually the unit leaking internal and dripping off the the fitting.
zombie1969 is offline
post #13 of 13 (permalink) Old Jul 19th, 17, 10:14 PM
Weldon
I used the same set of fittings for my Classic Instruments oil pressure sender.
Works really well and clears the Pertronix distributor with room to spare.
See the red circle. (Disregard the Ryobi oil pump drive tool.)
Name:	Engine Bay 72416 4 a.jpg
Weldon
64 El Camino
2011 Harley-Davidson TriGlide
Team Chevelle #5157
wihaltom is offline
This Thread is more than 1113 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
