Distributor wiring puzzle - Page 2 - Chevelle Tech
 4Likes
post #16 of 18 (permalink) Old May 31st, 17, 5:11 AM
Geoff
Re: Distributor wiring puzzle
Some GM models can get a back feed from the alt to keep HEI running after the ign is switched off. A diode fixes the problem. MSD had a diagram on their website showing where to connect the diode.
Gtogeoff is offline
post #17 of 18 (permalink) Old Jun 3rd, 17, 8:28 PM Thread Starter
Just to follow up and close on this - it was the gen light circuit backfeeding the entire ignition circuit. A diode fixed the problem.
Just a note - the IGN terminal in the fuse box was being backfed as well, so using that terminal wouldn't have helped either.
lucifershammer is offline
post #18 of 18 (permalink) Old Jun 3rd, 17, 10:19 PM
NTE 116 is the correct diode.
Fix the regulator.
Dave Ray is offline
This Thread is more than 1100 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
