1964 El Camino Stereo Install - Chevelle Tech
post #1 of 9 (permalink) Old May 8th, 17, 8:17 AM Thread Starter
Clyde
Recently, I replaced my original radio with one of the well advertised AM/FM/USB units. Turned out to be a very low quality piece of Chinese made garbage. Nothing but trouble. My question is: Is there a quality, trouble free, unit available that you guys out there are using? Must have 4 channel RCA outputs as I will be using a Boss Amp. All input will be greatly appreciated. Thanks
w7qhhcf is offline
post #2 of 9 (permalink) Old May 8th, 17, 11:09 AM
gary
Re: 1964 El Camino Stereo Install
I have a retro sound that is good.
post #3 of 9 (permalink) Old May 8th, 17, 12:29 PM
Sean
Very happy with what I just installed but it only has one set of RCA outs. See thread on 1969 Chevelle radio...the company should make a replacement for your factory radio but the features will likely be exactly like the one I bought.
swilk427 is offline
post #4 of 9 (permalink) Old May 8th, 17, 6:22 PM
What brand unit did you buy?
oldcutlass is offline
post #5 of 9 (permalink) Old May 9th, 17, 9:34 AM Thread Starter
Clyde
It's the Custom Autosound USA-630
w7qhhcf is offline
post #6 of 9 (permalink) Old May 9th, 17, 9:39 AM
kevin
FWIW...took $20 and went to wal mart. they sell a nice dual brand usb / blue tooth /fm radio for that price that is very nice. kept my oe am radio in the dash and mounted the new radio in the top of my glove box. bought a repeater ($20) so the remote supplied with the new radio works without opening the glove box door. $65 for two pioneer 6x9s and $7.88 for two small tweeters to mount up front. sound is incredible and the blue tooth works great.
the heckler is offline
post #7 of 9 (permalink) Old May 9th, 17, 11:29 AM
I've installed that model in a few cars, has a 75w/channel amp. Why would you buy that one to run an external amp? What issues are you having with it?
post #8 of 9 (permalink) Old May 9th, 17, 3:34 PM
Rob
Go with one of the higher end Pioneer head units.
My build thread> https://www.chevelles.com/forums/showthread.php?t=613546
65chevelle300post is offline
post #9 of 9 (permalink) Old May 9th, 17, 6:37 PM Thread Starter
Clyde
The only problem I'm having now is alternator whine that I have tried everything known to man to get rid of including winding coils of wire around ferrite cores and inserting them in the 12 volt and memory leads going into the head unit. I have some ground lood isolators coming, I doubt that they will help. I'm wondering if there is anything I could install at the output of the alternator, capacitor, choke, etc.?? The alternator is and old GM 10S1, probably from the 70's. Maybe a new one would be in order. Thanks for the posts, Clyde
w7qhhcf is offline
This Thread is more than 747 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
