Blinkers - Chevelle Tech
post #1 of 4 (permalink) Old Jul 18th, 05, 7:16 PM Thread Starter
Question Blinkers
I've got the same blinker problem as i have read about a dozen times, all outside blikers work fine all the time but when you turn the dash lights on the inside blinker indicators stay on and can be dimmed with the headlight switch. Disconnecting the front blinkers turns off the indicators. Cutting the blue wires for the blinkers also turns of the indicators. I've also tried to replace every piece in the blinker circuit from another chevelle that everything works on. No change. And checking all my grounds, including the blinker bulbs. I'm at my witts end with this. I really think it is a ground but i just can't find it. Any suggestions?
custom classics is offline
post #2 of 4 (permalink) Old Jul 18th, 05, 10:02 PM
Re: Blinkers
What vehicle?
Sounds like a lost ground to the dash lights maybe.
post #3 of 4 (permalink) Old Jul 19th, 05, 12:30 AM
Hey You!
Re: Blinkers
Sounds like a 70 or earlier car with a lost ground on the front turn signal bulbs. All is well until you turn on the running lights.
Yo-ho Yo-ho a pirate's life for me.
John_Muha is offline
post #4 of 4 (permalink) Old Jul 19th, 05, 9:01 AM Thread Starter
Re: Blinkers
THE CAR IS A 70 CONVERT CHEVELLE. i'VE TRIED ALL THE GROUNDS I CAN FIND. STILL THINK IT IS A GROUND BUT JUST DON'T KNOW WHERE ELSE TO LOOK. tHE CAR HAS BEEN COMPLETELY NUT AND BOLT RESTORED, THIS IS THE LAST THING TO DO ON THIS CAR BEFORE IT IS DONE!! tHANKS FOR YOUR HELP!!
This Thread is more than 5143 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
blinkers rchevellea Electrical & Wiring 1 Apr 12th, 05 9:42 AM
BLINKERS Ray70ss Electrical & Wiring 9 Mar 24th, 04 10:04 PM
dash lights and blinkers Beeftrain99 Electrical & Wiring 3 Aug 3rd, 03 2:38 PM
Making Marker Lights Flash With Blinkers TimC Electrical & Wiring 24 May 27th, 02 11:15 AM
blinkers azurite Troubleshooting 9 Dec 28th, 01 10:42 PM
