NO Fire in the Hole!!! - Chevelle Tech
post #1 of 2 (permalink) Old Jul 17th, 05, 11:12 PM Thread Starter
Well, I turned the ignition switch on for the first time on my newly restored '67 SS and nothing happened at the starter. However, the following things do work:
1) Dash "oil" warning light comes on (no other warning lights come on)
2) Headlights work
3) Hornes work
All harnesses are new under the hood, and the dash harness too. New junction block and horn relay. New Hei in place of old points distributor (I think it is hooked up correctly, but not completely sure).
What would be the basic areas to begin trouble-shooting?
Thanks, Charles
1967chevelless396 is offline
post #2 of 2 (permalink) Old Jul 18th, 05, 12:16 AM
Greg
Re: NO Fire in the Hole!!!
You mean the start position, right? Make sure the wiring is correct at the starter, 12g purple to the "S" terminal, yellow 20g to the "R" terminal. First see if you have 12 volts on the purple wire going to the "S" terminal at the starter. Next disconnect purple wire for and check for 12 volts in the start position, if no voltage, check both terminals of the neutral safety switch. Post back with results.
Greg U
undee70ss is offline
This Thread is more than 5305 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Fire in the hole BLT4FN 2005 2 Apr 22nd, 05 1:14 PM
Fire in the hole! lil rat replacement part III 10secBu 2005 18 Apr 4th, 05 4:16 PM
pic of heater core hole in fire wall KNIGHT07731 Body Shop 2 Jul 13th, 04 6:36 PM
There's Fire in the Hole (Finally) DaDon 1999 -- 4 Jul 20th, 99 7:28 AM
