A/C Blower Quit - Page 2 - Chevelle Tech
post #16 of 24 (permalink) Old Jul 20th, 05, 1:08 AM
Re: A/C Blower Quit
Did you make sure the ground wire had a good connection to the blower housing?
If so, sounds like a bad motor.
post #17 of 24 (permalink) Old Jul 20th, 05, 1:12 PM Thread Starter
Re: A/C Blower Quit
Thats kind of what I thought. Looks like the purple wire goes straight to the blower. I can replace the blower this weekend. Thanks for the advice.
"SSuper Dave" Palmer
A.C.E.S. #1483 TC #32 Gold
SSuper Dave is offline
post #18 of 24 (permalink) Old Jul 20th, 05, 1:45 PM
Re: A/C Blower Quit
Ya know, it's a little strange that the motor just stopped working. Usually they start making some noise before they die.
Just for grins and giggles, might want to check to see if there is power on the purple wire before you pull the motor.
Select heat or AC on the slide levers.
Set the fan speed to HIGH.
Put one lead of the test light on the purple wire.
Connect the other lead of the test light to a known good ground.
The test light should light up if there is power. (12 volts)
John_Muha is offline
post #19 of 24 (permalink) Old Jul 20th, 05, 3:55 PM Thread Starter
Re: A/C Blower Quit
Thats what I thought too. All the ones I've had go bad in the past were noisy first. I will check the wire for power when I get home tonight and post back. Thanks.
post #20 of 24 (permalink) Old Jul 20th, 05, 10:21 PM Thread Starter
Re: A/C Blower Quit
Now I'm really confused! With the a/c on, high blower on, key on, the test light does not come on at the purple wire. I even pulled the connector loose and checked it at the spade on the hi blower relay that the purple wire fastens to, and no power there either. I doubt that the switch and blower both failed at the same time.
post #21 of 24 (permalink) Old Jul 21st, 05, 12:30 AM
Re: A/C Blower Quit
Me too. See anything on the relay control wire? That should be a blue wire. Use your test light to ground with everything selected and the switch to high.
post #22 of 24 (permalink) Old Jul 21st, 05, 3:44 PM Thread Starter
Re: A/C Blower Quit
Finally I have power somewhere! With all the switches on, the blue wire lights the test light. It looks like the switch is good maybe the relay and the blower crapped out together?
post #23 of 24 (permalink) Old Jul 21st, 05, 5:05 PM
Re: A/C Blower Quit
Blue is the control (coil) wire for the relay.
Blue's power comes from the inside switches so that's a good sign. (Might be no problems under the dash).
If you move the inside speed selector switch from HIGH to MEDIUM, the relay should go "click-click"
Any power on relay orange wire? It should be hot even when the car is off. It comes from the horn relay on the front core support. There's an in-line fuse in this wire. It's hiding inside the plastic gutter on the firewall, behind the distributor. Maybe the fuse popped.
post #24 of 24 (permalink) Old Jul 21st, 05, 5:20 PM Thread Starter
Re: A/C Blower Quit
I will try moving the switch and listening for the click. The orange wire has power on both sides of the fuse, I checked it the other day since I replaced it with a newer blade style fuse holder last year when it melted.
This Thread is more than 5330 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Cam help, 177 blower on 454, looking for 600 hp stevenb8 2005 11 Jun 1st, 05 10:00 AM
Blower guys I need some help please, induction and cam stevenb8 2005 4 May 18th, 05 11:52 PM
A/C Blower Problem SSuper Dave Electrical & Wiring 5 Jun 9th, 04 12:12 AM
Blower relay wiring + other questions. 71wanna-be-ss Electrical & Wiring 1 Jun 2nd, 03 10:41 AM
Hi blower quit, what to check? ss_72man Electrical & Wiring 4 May 28th, 03 11:08 AM
