Painless - Internal Alternator - Chevelle Tech
post #1 of 6 (permalink) Old Jul 17th, 05, 3:05 PM Thread Starter
Unhappy Painless - Internal Alternator
We are just getting started on installing a Painless 18-circuit wiring harness. We are having a problem with correctly wiring up the internal alternator. We had problems with the alternator from the start when we purchased the car from a previous owner. We ended up taking it into an auto electrical shop and after installing a diode from terminal 1 to terminal 2 - all was well. Now with the painless wiring it is saying to attach the exciter (white) wire to terminal one and then have a jumper from terminal two to the alternator output lug (we currently have this jumper in now). It then shows to attach a wire that originates from the fuse block to the alternator output lug and that is supposed to be it.
We currently have a wire from the battery to the output lug, the diode from terminal 1 to terminal 2, and then the jumper from terminal 2 to the output lug. Additionally, two blue wires come off the output plug and go through the firewall.
Should we just go ahead and connect the exciter wire to terminal 1 (even though no wires go there now), keep the jumper and attach the wire from the fuse block to the output lug as directed? It doesn't seem to make sense as it doesn't call for any wires to hook up to the battery. As you can tell neither my husband nor I are expert auto electicians, so any help would be greatly apprecitated. Painless' support is closed today and I have read they are not too helpful anyway.
Thanks so much.
Damsel007 is offline
post #2 of 6 (permalink) Old Jul 17th, 05, 9:34 PM
Greg
Re: Painless - Internal Alternator
I don't see how
Yes, this wire should have 12 volts with the in the on position, zero volts with the key off and should go through a idiot light.
Pin 2 should go to the horn relay, jumping it to the alternator output lug only mimics a 1 wire alternator
How does the fuse box tie in with the horn relay? Are you using any of the original wiring?
Yes, and lose the diode
Thanks so much.
Normally the output wire and Pin 2 ( the sense wire) go to the horn relay You can read about alternators and wiring them here
http://www.madelectrical.com/electr...delcoremy.shtml
and here
http://www.madelectrical.com/electr...threewire.shtml
Greg U
undee70ss is offline
post #3 of 6 (permalink) Old Jul 18th, 05, 12:28 AM
Ryan
Ooops, sorry i didn't chime in earlier, hook it up the way they say. The horn relay has been moved to the fuse bolck so you don't need that. If you hook it up as they say, it works! LOL, i just finished installing this kit so if you have ANY questions i can answer them. BTW, what year car is it?
rianbechtold is offline
post #4 of 6 (permalink) Old Jul 18th, 05, 10:32 PM
I'm with the others. A diode between terminals 1 & 2 makes no sense whatsoever. Get it out of there.
The wire going to terminal 1 probably comes from the alternator light connection. Otherwise, Painless must put a resistor of some sort in the wire.
The wire from terminal 2 is the voltage sensing and needs to be connected to battery voltage. The alternator will keep the voltage at the point where that #2 wire is connected regulated. In other words, it will keep the voltage where that wire is connected at 14.3V. So, you should connect wire #2 to the junction block where the largest loads (electric fans) are connected.
Peter
Peter F. is offline
post #5 of 6 (permalink) Old Jul 19th, 05, 10:16 PM Thread Starter
It is a 65 SS. We will proceed with it this weekend and let you know how it goes. Work is slow when we are working in 115 degree heat in a garage : - )
post #6 of 6 (permalink) Old Jul 20th, 05, 3:43 AM
Greg
I here the there, one these days I'm installing a air conditioner in the garage.
Greg U
This Thread is more than 5150 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Wiring an Internal Regulator Alternator sudolg Electrical & Wiring 22 Jun 19th, 05 7:57 AM
Internal versus external voltage regulator problem Steve Petzer Electrical & Wiring 1 Nov 9th, 03 1:53 PM
trying to bolt on an internal reg. alternator in a 69 BB mike69ss Electrical & Wiring 2 Mar 27th, 03 5:02 PM
Need a guru's help! CS-130 alternator wiring with idiot light rodneyaz Electrical & Wiring 6 Dec 6th, 02 9:46 PM
Alternator w/ Internal reg and Voltage Regulator Skier_Bob 1999 -- 12 Apr 12th, 99 7:10 PM
