help with weird dome light problem - Chevelle Tech
post #1 of 3 (permalink) Old Jul 17th, 05, 12:07 PM Thread Starter
hello,
I have a 68 malibu and i am having a problem with my dome light and oil pressure light.
I ran new hot and ground wires to the dome light before I had my headliner installed.(I know that the ground is what is broken by the door switch) everything was fine until....I installed a console and hooked up the wiring for its light. I ran the console lights hot wire directly to the side of the fuse box which is hot all the time (not controlled by the ignition switch) and hooked the ground wire into the ground wire I installed for the headliner dome light. Every thing works fine, but now my engine light comes on! It will do this intermittintly even with the engine off and no key in the ignition. Needless to say this runs down my battery. Must be a problem with the ground somewhere. Hopefully someone here can give me some possible things to check. THANKS!
68maliboo is offline
post #2 of 3 (permalink) Old Jul 17th, 05, 2:45 PM
Hey You!
Re: help with weird dome light problem
Everything sounds close. What happens if you unplug the console hot wire from the fuse block? Does the oil light start behaving itself?
Maybe tie the console hot wire to the LAMPS circuit so they come on with the headlight switch and not the door switch.
Yo-ho Yo-ho a pirate's life for me.
John_Muha is offline
post #3 of 3 (permalink) Old Jul 17th, 05, 7:17 PM
Captain Morgan
are you talking about the light on the rear of the console ?
the hot should be hooked to the orange wire that is always hot
then the ground is broken by the door switches and dome lamp switch on the lightswitch
with the hot wire hooked to the fuse box - it may be backfeeding through another circuit
you also may want to check if the glove box lamp is working properly and has no shorts
Cars and Guitars
Tom's 68 is offline
This Thread is more than 5060 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Windshield Wiper Problem on '68 SS 68SS396chevelle Troubleshooting 6 May 15th, 05 8:29 AM
turn signal & reverse light problem blm Electrical & Wiring 5 Apr 19th, 05 4:28 PM
Dome light question -'67 SS 67Chevelleguy Interiors 2 May 4th, 04 8:27 AM
Problem: Brake light on dash comes on with headlights gerald 1999 -- 4 May 31st, 99 9:25 PM
dome light elc66 1999 -- 2 Mar 22nd, 99 1:42 PM
