Two batterys - Chevelle Tech
post #1 of 14 (permalink) Old Jul 15th, 05, 10:04 PM Thread Starter
Two batterys
To run two batt's do you need a different type of alt?Do you need to change some things? How does it work? Been having some problems with car stops runnung and when i try to restart the batt is dead.I run a small alt that only puts out 50 amps and was wondering if that is to small? BILL
Sold May 09
540 BIG BLOCK
10.10 @ 130 ON MOTOR
9.47 @139 ON 175 HIT
driver is offline
post #2 of 14 (permalink) Old Jul 15th, 05, 10:16 PM
Re: Two batterys
With the battery technology today, there isn't really a reason to need two batteries. What's your problem that you want them?
MedicTed is offline
post #3 of 14 (permalink) Old Jul 15th, 05, 10:19 PM Thread Starter
Re: Two batterys
I added to my 1st post telling everythimg.THANKS
Sold May 09
540 BIG BLOCK
driver is offline
post #4 of 14 (permalink) Old Jul 15th, 05, 10:46 PM Thread Starter
Re: Two batterys
Anybody?????
Sold May 09
540 BIG BLOCK
driver is offline
post #5 of 14 (permalink) Old Jul 16th, 05, 1:33 AM
Greg
Re: Two battery's
Normally no, but only a 50 amp alternator would be to small if you had very many accessories running too. Also alternators are rated by their max output, they put out much less at idle and slower speeds.
Depends on how its wired and what you want to do, run both at the same time, run one and just charged the other, keeping it as a spare.
Been having some problems with car stops running and when i try to restart the batt is dead.I run a small alt that only puts out 50 amps and was wondering if that is to small? BILL
Is this for the Nova in your sig? Street/Strip or drag only??? How many accessories do you have. First make sure the alternator even working, check the voltage across the battery with the car running at a fast idle. You need 14-14.5 volts at the battery to be charging it. The reason the car stops running is you are most likely just running off the battery, when the voltage drops low enough, dead battery.
Greg U
undee70ss is offline
post #6 of 14 (permalink) Old Jul 16th, 05, 7:34 AM Thread Starter
Re: Two batterys
Thanks thats what i was thinking.It's the nova and it's pro street/race.I have a 7al2 box,lights,signals,horn and thats about it.No radio,no nitrous yet.I'll check it out a little deeper today,Thanks again. I forgot about the electric water pump and twin fans.
Sold May 09
540 BIG BLOCK
driver is offline
post #7 of 14 (permalink) Old Jul 16th, 05, 9:25 AM
Hank
Re: Two batterys
Twin fans, that could be it right there. They could easily draw more than the alt puts out at idle. They may even take all of the alternator output while driving which means anything else, ign, water pump, etc. are running off the battery. I would say a bigger alt is in order given your setup.
Hank
Finally is offline
post #8 of 14 (permalink) Old Jul 16th, 05, 11:48 AM
Re: Two batterys
No two batteries are identical. One will always be weaker than the other and cause one battery to try and charge the other one. There are a couple of ways to prevent this, one being a battery isolator such as this.
http://www.geocities.com/harald_nancy/isolator.htm
John_Muha is offline
post #9 of 14 (permalink) Old Jul 16th, 05, 1:16 PM Thread Starter
Re: Two batterys
Did some testing and this is what i have.Tested the alt at around 2000 rpms and it's putting out 12.2/maybe 12.4 volts.Tested battery at idle it's around 11.0 volts and at 2000 rpms it's close to 12 volts.Both are brand new.Alt is a mini east coast 55 amp and the batt is a red top.So whats the bad one???
Alt or battery?? Doing the testing each time i had to recharge the battery.I have a 90 amp alt in my garage but it's full size and i would need to do a bunch of changing to get it to work??THANKS,BILL
Sold May 09
540 BIG BLOCK
driver is offline
post #10 of 14 (permalink) Old Jul 16th, 05, 2:06 PM
Re: Two batterys
Alt or battery?? Doing the testing each time i had to recharge the battery.??THANKS,BILL
Sounds like the alternator is not putting out.Is it wired correctly? Optimum alternator voltage should be 13.8 to 14.2 at that rpm.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #11 of 14 (permalink) Old Jul 16th, 05, 2:08 PM
Re: Two batterys
First check you alternator belt and make sure it doesn't slip. Turn off the motor, grab the alternator fan and try to turn it by hand. If you can turn it using minimal or moderate force then you need to tighten or replace it.
Make sure your battery is fully charged and tested. If you don't have a battery tester then visit your local sears or any place that sell batteries. A low or bad battery will not allow an accurate voltage check of the charging system.
Start your engine, the voltage should be at around 13.5 - 14v when you're at 3,000 rpm. If it's still at 12.something then you have a problem in the charging system.
As for the current used by your accessories, it's a complicated test that requires an amp meter. Best to go to an auto electrician for this. But in my opinion, you have a charging system problem.
I would not recommend putting another battery in you car. More components means more that can go wrong!
georgem is offline
post #12 of 14 (permalink) Old Jul 16th, 05, 2:08 PM Thread Starter
Re: Two batterys
Wired correct,one wire going to the battery.
Sold May 09
540 BIG BLOCK
driver is offline
post #13 of 14 (permalink) Old Jul 16th, 05, 3:10 PM
Greg
Re: Two batterys
Alt or battery??
1 wire alternators need to be revved to be started. Depending on the crank and alternator pulley sizes this could be anywhere from 1200-3500+ rpm. Whats the diameter of the crank and alternator pulleys? Do the voltage test again, make sure everything that can be turned off is ( water pump, fans ect...). Make sure to blip the throttle to start the alternator. Then hold at 2000 rpm. If your not getting 14+ then the alternators bad. With all the accessories you have I would look consider a 100 amp alternator wired as a 3 wire.
Greg U
post #14 of 14 (permalink) Old Jul 16th, 05, 10:58 PM Thread Starter
Re: Two batterys
Thanks,i got it fixed.I replaced the alt with a 90 amp alt and hit the gas it goes up to 14+ where the other one would not go past 12.4.Still need to check at battery which I'll do in the morning.Thanks for all the help everyone.BILL
Sold May 09
540 BIG BLOCK
driver is offline
This Thread is more than 5232 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
A good performer Battery.... feedphillipnow 2005 24 May 14th, 05 2:29 PM
battery's and starter solenoid's 69chevelle355 Electrical & Wiring 4 Mar 20th, 05 8:04 PM
