Horn Questions - Chevelle Tech
post #1 of 2 (permalink) Old Jul 14th, 05, 10:19 PM Thread Starter
Horn Questions
hey guys, on my newly acquired 66 chevelle, the horn doesnt work, where would i start to start troubleshooting the problem and what all is involved in the horn system to work, the horns are in the car and hooked up, fuses are good.....what do i do ,thanks to all for your help! god bless and thanks!!!!!
tvprofessor is offline
post #2 of 2 (permalink) Old Jul 14th, 05, 10:26 PM
Re: Horn Questions
check to see If the horn relay Is good or you can see If the horn Is good by running a hot wire from the battery direct to the horn, and then you can take the horn button loose from the steering wheel and check the little brace button and see If Its worn.
juggie1 is offline
This Thread is more than 5155 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Horn Relay Agugliel72SS Electrical & Wiring 6 Jul 15th, 02 12:30 PM
69 Chevelle Horn Relay Questions Georgia69 Electrical & Wiring 2 Nov 26th, 01 1:46 PM
Lecarra and horn contact DaleM Electrical & Wiring 1 Oct 24th, 01 8:49 AM
Yet Another Horn Problem Again LHULL Electrical & Wiring 3 Jul 11th, 01 7:36 AM
