Switched 12v - Chevelle Tech
 2Likes
  • 1 Post By oldcutlass
  • 1 Post By 70CHEVELLE396
post #1 of 14 (permalink) Old Apr 13th, 17, 11:17 AM Thread Starter
Switched 12v
I need to find a clean switched 12v source to wire in my Sniper efi. I have something on the ign terminal on the fuse box. It needs 12v during cranking as well. This is on my 70 Chevelle with stock wiring. Sorry I'm just not that confident with this stuff. If anyome could point me in the right direction, I'd appreciate it.
70CHEVELLE396 is offline
post #2 of 14 (permalink) Old Apr 13th, 17, 11:55 AM
Andy
Re: Switched 12v
When I wired my MSD box up I used the original coil + wire.
All I learned in high school is I am not Earnhardt and I am not invincible
Andrewjreynolds85 is offline
post #3 of 14 (permalink) Old Apr 13th, 17, 12:04 PM
Rob
Re: Switched 12v
The ignition terminal on the fuse panel should have power during cranking as well.
My build thread>
65chevelle300post is offline
post #4 of 14 (permalink) Old Apr 13th, 17, 12:36 PM Thread Starter
I'm running a wire from the ign terminal on the fuse box to a relay. That is powering my HEI distributor. So that's already being used.
post #5 of 14 (permalink) Old Apr 13th, 17, 1:13 PM
Re: Switched 12v
You can still use the IGNITION terminal, it will support more than just the HEI feed current levels. (On this, I am assuming the wire you need the current from, is much like an MSD operation wire, simply turns the Sniper system on and off? If so, no problem with using the IGNITION terminal, with the HEI).
When I run an HEI that I do, idle uses 3.5 amperes, red line, 1.3 to 1.5 amps total. Difference is tht at lower rpm's, there is more time in milliseconds for the coil to saturate, than at higher rpm levels, so, idle, more amperage use, red line, significantly less.
Dave Ray is offline
post #6 of 14 (permalink) Old Apr 13th, 17, 1:13 PM
Re: Switched 12v
Run a larger wire from the relay to a bus and use it as a switched source for the HEI and other applications.
70CHEVELLE396 likes this.
oldcutlass is offline
post #7 of 14 (permalink) Old Apr 13th, 17, 1:41 PM
Rob
Re: Switched 12v
It's easy enough to solder or crimp two wires to a single terminal as long as you don't exceed the amperage rating of the fuse which you won't be. You will have no issues if you do that.
My build thread>
post #8 of 14 (permalink) Old Apr 13th, 17, 1:52 PM
Re: Switched 12v
As Dave alluded to, the first thing we need to verify is, that this is simply a "trigger" wire with low current demands. If it is, then there is no issue with connecting on to the IGN slot on the fuseblock,
Coppertop is offline
post #9 of 14 (permalink) Old Apr 13th, 17, 3:21 PM Thread Starter
Ok sounds real good. I'll look into the demand for the Sniper system on that 12v switched lead (pink) wire. It also has a direct connection to the battery, so it most likely telling the system it's time to work! I do know through out the directions and any where you read, it's overly stressed that you have a "clean" source, and not to share circuits. Not sure if it's Holley's way to cover there butt, or if it's for good reason.
post #10 of 14 (permalink) Old Apr 13th, 17, 4:35 PM
Hank
Re: Switched 12v
If you can run 2 wires off the same terminal you can pick up some of these.
Advance Auto Parts - Down for Maintenance
HKalin is offline
post #11 of 14 (permalink) Old Apr 13th, 17, 5:20 PM Thread Starter
Thanks Hank, I do have some of those.
HKalin likes this.
post #12 of 14 (permalink) Old Apr 13th, 17, 7:57 PM Thread Starter
Re: Switched 12v
Actually all it's doing is powering the relay. The relay then gets full battery voltage off the horn relay, and that powers the HEI.
post #13 of 14 (permalink) Old Apr 14th, 17, 1:02 PM
Re: Switched 12v
I am a very firm believer in NOT USING RELAYS for anything, just another problem to work around when they go bad, regularly.
Although the IGNITION and IGN terminals are housed in the fuse box, they are NOT fused. I have run as much as 20 amperes load off them, with no adverse effects, including multiples of things like MSD power on switch, EFI power on (Holley and other systems), electric chokes, and other things they are needed for.
Dave Ray is offline
post #14 of 14 (permalink) Old Apr 14th, 17, 1:55 PM
Re: Switched 12v
I think you need to clarify Dave.
The "add on" slots readily accessible from the front side of the fuse block with the rest of the fuses are fused. For example, talking 1970 here, the IGN slot is protected by the turn signal fuse.
If you go in thru the other side (i.e. remove the original points ignition resistance wire to install a regular wire) at the bulkhead connections, then that ignition feed is NOT fused.
This Thread is more than 1147 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
