Battery Cables - Chevelle Tech
post #1 of 15 (permalink) Old Jul 12th, 05, 5:06 PM Thread Starter
Paul
Battery Cables
This may sound kinda dumb but does any one know where i could get some aftermarket battery cables that arent stock and arent just the red and black ones taht you can get from the parts store. Ive looked in summit and jegs and stuff like that and nothing that is really that nice or anything. I have a 71 chevelle with a sb 400 and an optima battery and im looking to go with the side posts b/c my top posts were getting to dirty and nasty on the other battery. Oh and what is the best length wire to go with on my car, i bought new cables a while ago and dont remember the length of the positive cable. Thanks guys.
'71SB409 is offline
post #2 of 15 (permalink) Old Jul 12th, 05, 5:34 PM
Greg
Re: Battery Cables
What exactly are you looking for, HD cables or something that is fancy? I have seen some that looked like braided hose that you could have made, even the terminals ends were fancy looking but I no longer have the link. Might try searching the web. For HD cables in the larger sizes you could make a set yourself ( I did) or buy ready made ones. Heres one place, there are many others
http://www.madelectrical.com/catalog/1-0.shtml
Greg U
MY 70SS
undee70ss is offline
post #3 of 15 (permalink) Old Jul 12th, 05, 5:43 PM Thread Starter
Paul
Re: Battery Cables
Well, i was looking for something pretty fancy and HD. Preferably premade. Thanks for the help.
'71SB409 is offline
post #4 of 15 (permalink) Old Jul 13th, 05, 8:26 AM
Re: Battery Cables
No premade stuff, but usually local auto stereo/audio stores such as Circuit City or Best Buys or HI-FI Buys all have custom stereo wires and connectors in brilliant colors and sizes, albeit them pricey.
I use all Monster Cables and connectors in my applications.
HOTRODSRJ is offline
post #5 of 15 (permalink) Old Jul 13th, 05, 9:20 PM
Dennis
Re: Battery Cables
Go to any RV/tractor repair facility. We make all our own cables. What would you like, 6ga, 4ga, 2ga, 0ga, 00ga, ring terminals, bolt on terminals, side mount terminals, red, black, gray, etc... you get the idea. Any tractor (Peterbilt, Freightliner, Volvo, Mack, Kenworth-the best) will have all this stuff in huge bulk quantities. Tell them how long and what type of ends and they can make them up in about 10 minutes.
Now will they.......that may take some pleading.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."
Thomas Jefferson
sinned is offline
post #6 of 15 (permalink) Old Jul 14th, 05, 11:51 PM Thread Starter
Paul
Re: Battery Cables
Well, thanks everyone. I just went to the Car audio store and bought 1/0 wire (really cheap oddly enough). Im just having trouble finding the connectors to go from the wire to the battery. Ill just buy ring terminlas for the starter and the ground. Thanks for all the help guys. It was greatly appreciated. And its too bad taht no one makes aftermarket nice looking battery cables, i thought for sure there would be a whole lot of other distributors out there that would make them, but obviously i was wrong. Thanks again!!
'71SB409 is offline
post #7 of 15 (permalink) Old Jul 15th, 05, 12:13 AM
Dennis
Re: Battery Cables
You would be suprised at how clean the farm/over-road tractor stuff can look. Far more reliable than the automotive stuff too.
Thomas Jefferson
sinned is offline
post #8 of 15 (permalink) Old Jul 15th, 05, 8:16 AM
Hank
Re: Battery Cables
Sounds like you bought wire used to power a big amp. It should but make sure the insulation is going to hold up to the heat, weather and other elements under the hood.
Hank
My Chevelle
Finally is offline
post #9 of 15 (permalink) Old Jul 15th, 05, 8:40 AM
Re: Battery Cables
Most of the battery cables that are in the high quality stereo stores are actually better equipped to handle the heat, moisture and abrasion than the OEM cable is! I will agree that some of it is junk, do your homework.
The Monster Ultra-flow 40 series is just an example. Yes ....it's used for wiring big amps too, but the heat rating is almost 50% higher and also higher grade insulation materials than any OEM. Looks great too.
I offer the following picture of my 69 Camaro's battery equipped with number 2 (all you will ever need for size....even if it's a trunk location rated at over 150amps continuous) Monster Ultra flow series wire with the Monster terminals too. I think it looks pretty good and works great....I use them in all applications.
The cable that many gearheads think is suitable for use under the hood is welding cable, which it's NOT! Welding cable is made with different insulation materials (and industry requirements) and does NOT perform well in hot locations and is prone to "wicking" which pulls moisture up the cable inside the insulation sheath and corroding away without an outside indication. All of a sudden one day your engine doesn't crank and one wonder's why. You can aleviate the later problem by making sure the ends of the cable are completely hermetically sealed with silicone. But, the heat factor remains.
post #10 of 15 (permalink) Old Jul 15th, 05, 8:47 AM
Hank
Re: Battery Cables
I agree you can get some good quality cable at an audio store, just need to make sure of what you're getting.
Hank
My Chevelle
Finally is offline
post #11 of 15 (permalink) Old Jul 15th, 05, 11:14 PM Thread Starter
Paul
Re: Battery Cables
well i found some 1/0 wire (they didnt sell 2 gauge b/c they said that if someone needed 2 gauge they would just tell them to spend a little extra for the 1/0 and get the better wire) Well i cant find and NICE looking side terminals for my battery now. I have the wire and can get the connectors for the wire, just no terminals to put on the wire then connect it to the battery. Any help guys. Thanks a lot
'71SB409 is offline
post #12 of 15 (permalink) Old Jul 16th, 05, 10:34 AM
Re: Battery Cables
Page 25 and 26 in the below catalog have some terminal ends that take 1/0 wire. Stinger also has 1/0 crimp on ends that I usually use at work and after crimping them on take my Mapp gas torch, heat up the end and then solder it. After it cools they have a rubber slide on boot to make it nicer.
http://aampofamerica.com/web/catalogs_pdf/SBRO05v2.pdf
Jim Streib is offline
post #13 of 15 (permalink) Old Jul 17th, 05, 10:17 AM
hrd
jayt
Re: Battery Cables
i got mine (i cant remember what gauge they are, but, they're huge) at napa...they had all kinds of size, length and end configurations, and im pretty sure they're for automotive use, with a ford type solenoid and and optima battery...ive never had a cranking problem since
1970 El Camino
“In the present weak state of human nature, surrounded as we are on all sides with ignorance and error, it little becomes poor, fallible man to be positive and dogmatical in his opinions.”...Benjamin Franklin
“Power concedes nothing. without a demand.”...Fredrick Douglas
hrd is offline
post #14 of 15 (permalink) Old Jul 20th, 05, 11:13 PM
Re: Battery Cables
these guys have a pretty good selection of lugs and connectors
http://www.solarseller.com/
I'm using their compression lugs. Very handy.
72 Orange is offline
post #15 of 15 (permalink) Old Jul 21st, 05, 1:27 AM
Re: Battery Cables
I know this is a little late but this guy will make whatever you want in whatever size you want.
www.custombatterycables.com
Scott W.
Electrical Engineer
'68 Malibu GM 383 700R4
This is how we roll:
It's still a Family affair!
red68chevL is offline
This Thread is more than 5056 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
fryed battery cables JayNavy Electrical & Wiring 4 Apr 19th, 05 12:23 PM
IN DIRE NEED OF HELP! Need help A.S.A.P. please! 71chevy0192 2005 47 Jan 28th, 05 12:14 AM
1965 Battery Cables JohnM Electrical & Wiring 6 Jun 25th, 02 10:09 PM
Do I need to ground my battery cables? 70Bowtie Electrical & Wiring 1 May 1st, 02 8:30 PM
spring ring battery cables bhawk 2000 7 Dec 11th, 00 5:59 PM
