Battery Terminal corrosion prevention? - Chevelle Tech
 4Likes
  • 1 Post By NickeyChevelle
  • 1 Post By Philip
  • 1 Post By Krister
  • 1 Post By joeyv69ragtop
post #1 of 15 (permalink) Old Feb 12th, 17, 8:21 PM Thread Starter
rkd
Ron
Just did some battery terminal maintenance and repair.
Does anyone use those washers from Autozone, or the sprays, or anything else on battery terminals.
I have never really found anything that seemed to work.
Whats everyone elses experience.
rkd is offline
post #2 of 15 (permalink) Old Feb 12th, 17, 8:38 PM
Bruce
Re: Battery Terminals
I lightly coat the posts and the cable ends with Dielectric Grease and I use the treated felt washers on the posts under the cables, and I've never had any corrosion issues since I started this practice.
68Cpe307 likes this.
Our You Tube Vids:
NickeyChevelle is offline
post #3 of 15 (permalink) Old Feb 13th, 17, 7:32 PM
If the post is leaking nothing will work. The felt things coated with dialectric grease and coating the terminal helps though. I had this problem on my DD after i replaced the battery the problem went away.
gspan1830 is offline
post #4 of 15 (permalink) Old Feb 13th, 17, 9:04 PM
I use wheel bearing grease..
hydro462 is offline
post #5 of 15 (permalink) Old Feb 13th, 17, 9:20 PM
Dielectric grease or spray a little fluid film on the cables after they are installed. We have a fleet of golf carts at work and I use fluid film and never have an issue and I'm talking alot of batteries.
Bonkerman is offline
post #6 of 15 (permalink) Old Feb 13th, 17, 9:29 PM
I use dielectric grease also.
One thing I did have to use last time(two months ago)I bought a battery at advance auto was those shim caps for the post.
The one post was normal size,the other post was much smaller,and the factory terminal could not tighten enough around it.
I cut about an 1/8" of an inch from around the bottom so it sat better on the terminal.It was a little too tall.
'67 Malibu,468 w/TH400
Project-
72LS3Z27 is offline
post #7 of 15 (permalink) Old Feb 16th, 17, 5:39 PM
I second the felt washers.
69' SS396 Chevelle L78 396/375hp M-21 Close Ratio Cortez Silver
10 year Resto
It's brand new again!
02' Harley FatBoy, Diamond Ice Pearl and lots of chrome!
ACES# 3466
fastss396man is offline
post #8 of 15 (permalink) Old Feb 16th, 17, 5:41 PM
David
I've used both. I use a spray battery protector and simply keep up on maintenance (which yes, includes cleaning batter terminals from time to time) Never really had a problem. Make sure you have good cables with good ends on them...
David
ACES#7432 TC#3213
Get In, Sit Down, Shut Up, Hold On
dmg1029 is offline
post #9 of 15 (permalink) Old Feb 16th, 17, 8:27 PM
Mac
I use the felt washers, and after installing the terminal on the post I spray the whole thing with NCP2, no worries
1970 Chevelle SS full weight street car (4030lbs)
498-11.5:1 (Mac built) 91 pump gas+
Strauby sissy roller -
brodix-rr rec 294
weiand stelth- Pro Systems 1000
turbo 400 10" 3200 Coan 4.10 12 bolt
Best Passes on28-10.5-15 slicks and 110
1.56-6.97-99.83
1.6194-11.1666-120.94
And a drag [email protected]
If it wasn't dangerous, it wouldn't be fun!
bigmachd is offline
post #10 of 15 (permalink) Old Feb 16th, 17, 9:04 PM
I run AGM batteries and the terminals do not need anything. The only thing that ever needs cleaned off the battery is dust.
65chevelle300post likes this.
63 Nova wagon
Philip is offline
post #11 of 15 (permalink) Old Feb 16th, 17, 9:06 PM
rick
X2 with bearing grease, since I work on a/c units I have tubes of die elec grease that I use, but learned about wheel bearing grease from a farmer in the 70's, X? a lot with the washers
shovelrick is offline
post #12 of 15 (permalink) Old Feb 17th, 17, 2:02 PM
Krister
X2 been doing this for years with no issues and look as it as preventive. I have an 10 oz bottle of dielectric Grease from my dads electrician days - it will last me a life time and my kids. Beats the little packet the auto parts sell as an "impulse buy" at the register.
NickeyChevelle likes this.
Krister
'66 SS, L34, 4spd (M21), 3.73 posi, #'s Matching, G 5C
- like I would have ordered, but I was 2
Krister is offline
post #13 of 15 (permalink) Old Feb 17th, 17, 2:29 PM
felt washers and dielectric grease here. Battery went a full lifetime and got turned in as a core on a new one and never a speck of corrosion on the terminals.
-Joe
Team Chevelle #2680
'69 Malibu Convertible
joeyv69ragtop is offline
post #14 of 15 (permalink) Old Feb 17th, 17, 7:25 PM
Re: Battery Terminal corrosion prevention?
Felt washers and a tad bit of tranny fluid on the washers for extra measure here. Dozers, trucks, Chevelle, tractors, you name it.
edspdog is offline
post #15 of 15 (permalink) Old Feb 17th, 17, 7:31 PM
Rob
I used to use the Permatex 80370 but that was before AGM battery's which are clean as can be.
My build thread>
65chevelle300post is offline
This Thread is more than 1239 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
