71 Chevelle Gauge Pillar Mount - Looking for source - Chevelle Tech
post #1 of 16 (permalink) Old Jan 1st, 17, 2:10 PM Thread Starter
Exploring using Gauge Pillar mount for my gauges......looking but not find any yet for 71 Chevelle. Anyone using Pillar Mount? Happy with them? I used to have my gauges under the dash and am trying to use different approach.... options are mounting on top of the console nearest the firewall and pillar mount............. Where did you find them? Thanks
Skier_Bob is offline
post #2 of 16 (permalink) Old Jan 1st, 17, 6:57 PM
Vince
Re: 71 Chevelle Gauge Pillar Mount - Looking for source
here is a pillar mount...
Autometer Pillar Gauge Pod Dual 2 1/16 Chevrolet Chevelle 10183 | eBay
VinceS427bb is online now
post #3 of 16 (permalink) Old Jan 1st, 17, 8:10 PM Thread Starter
Thanks Vince!..... see any 3 gauge ones? Was hoping to find one to hold 3......
post #4 of 16 (permalink) Old Jan 1st, 17, 8:25 PM
What about this one:
1972 Chevelle, 454, 2004r, 3.08
lucifershammer is online now
post #5 of 16 (permalink) Old Jan 1st, 17, 8:29 PM Thread Starter
Cool Re: 71 Chevelle Gauge Pillar Mount - Looking for source
COOL! Can't beat it for $17! THANKS. just ordered it! Will let you know how it works out!!!
post #6 of 16 (permalink) Old Jan 1st, 17, 9:16 PM
Excellent. I'd love to see some pics of it installed and how the angle of the gauges works for viewing. I was considering this myself, but am still debating between pillar mount or just under dash.
post #7 of 16 (permalink) Old Jan 15th, 17, 10:33 PM Thread Starter
Received and mounted the 'universal' triple gauge pod.... pics below. takeaways follow:
1. universal means doesn't quite fit, or kind fits
2. purchased another set of pillar mounts so I wouldn't mess up my originals.....so the $16 universal pod cost went up by $100.....bought the set of urethane pillars (NPD) - not bad but different mounting holes to pillar - so new holes to drill.
3. since the pod didn't quite cleanly align with the pillar, I decided to mount it with screws....worked ok but certainly not the standards of Team Chevelle top work.
4. wiring went well. another step closer to back on the road.
5. I will see how the pillar pod holds up.....and let you all know....
ID:	414186   Click image for larger version
post #8 of 16 (permalink) Old Jan 16th, 17, 12:26 AM
I like the way that looks but I'm confused. Is that the three gauge pod from Amazon or one that I can't find at NPD?
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is online now
post #9 of 16 (permalink) Old Jan 16th, 17, 6:44 AM
Thanks for the follow up, those look good.
When sitting in the car, how well can you see the gauges? Any issue with the angles, or the height of that upper gauge?
I'm still debating on 3 or 2 - I really only need to mount an AFR and Trans Temp gauge. If I go for 3, the 3rd would be a vacuum gauge (not really necessary, but can be useful...)
post #10 of 16 (permalink) Old Jan 16th, 17, 10:06 AM Thread Starter
its the 3 gauge pod from amazon.....made by Glow Shift...it is supposed to come with installation kit (screws, screw hole cover tabs,etc) but did not... height and angle of all three gauges is good.
post #11 of 16 (permalink) Old Jan 17th, 17, 11:28 AM
Darren
Looks good, I wonder if a little heat gun action might help to manipulate the pod casing for a better mating surface?
Also noticed you have a full gauge dash, why the redundancy?
If you donít push the limits how are you going to find the weak spots?
USMC- Retired
My car: 1970 Chevelle
Factory 12 bolt /4-Speed Malibu -Dual stage wet nitrous with heater & purge - Holley Strip Dominator, Speed Demon 750 CFM - (All MSD distributor, blaster 3 coil, 6AL, & 3 stage retard) - 4 wheel disk brakes - Aeromotive Fuel system Ė Boss 338 18ís - BMW 5.25 true HID projector mod - and of course... the FLAPPER - bla, bla, bla.. lots of other expensive stuff I canít remember
70 nialator is offline
post #12 of 16 (permalink) Old Jan 18th, 17, 12:52 PM Thread Starter
Darren - heat gun probably would have been good move.... I wound up using screws, epoxy, and some black caulking to seal.....heat gun would have been better.... I am not qualified on heat gun yet......have never even fam fired one. OOORAH! As far as redundancy, good point...... guess I wanted more accurate gauges especially for water temp and oil pressure.. I did get rid of the big ol extra tach I had on the steering wheel though! Using a dummy set of pillars lets me experiment.
70 nialator likes this.
post #13 of 16 (permalink) Old Jan 19th, 17, 3:13 PM
Looks nice. How is ingress/egress? How does it look from outside the car with the door closed?
70GS455 is offline
post #14 of 16 (permalink) Old Jan 19th, 17, 10:30 PM Thread Starter
ingress/egress good - no head bonks yet...... looks good from both windshield and side views.....I'll upload some pics
post #15 of 16 (permalink) Old May 27th, 18, 6:59 PM
Stu
Just sort of a data point but I have a 2-gauge pillar in my chevelle, but since they only make them for coupes and I have a vert I did in fact have to use a heat gun. Worked well. This was years ago, but I just came across this thread while looking to see 3-pod options were out there.
L92 / 200-4r -> T56 71
chuckd71 is offline
This Thread is more than 420 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
