70-72 dash swap wiring - Chevelle Tech
 6Likes
  • 1 Post By fishhead
  • 2 Post By Bart_Swisher
  • 1 Post By 70SSTHUMPER
  • 1 Post By 70 nialator
  • 1 Post By RealRed70
post #1 of 15 (permalink) Old Nov 17th, 16, 12:18 PM Thread Starter
Randy
I have a 70 Malibu with sweep dash. I bought a 72 gauge dash, which includes the wiring harness all the way back to the fuse box. It would be easier to leave the 70 wiring harness in the car, but I know some of the wiring is not the same (gas gauge, for one). I do have an assembly manual. Has anyone done this swap, and what was your experience? I'm just asking for advice here, not here to argue about what type of dash or gauges to use.
thanks,
Rat
1970 Chevelle Malibu. Red. Did it come in another color?
rattracer is offline
post #2 of 15 (permalink) Old Nov 17th, 16, 12:57 PM
Shane
Re: 70-72 dash swap wiring
thanks,
Rat
Seems like you've been here awhile...lol. Love your post. Good luck, hope you find your answer. If it were me, i'd probably take both harnesses out, lay them out, cut the wrap in spots and splice in the correct wires for you dash. Rewrap and install.
68-13427 likes this.
fishhead is offline
post #3 of 15 (permalink) Old Nov 17th, 16, 1:13 PM
Bart
Ask and you shall receive.. This link will give you everything you need to make the swap.
1972 Chevelle SS Wiring Diagram and Pictures
rattracer and 68-13427 like this.
Bart_Swisher is offline
post #4 of 15 (permalink) Old Nov 17th, 16, 1:28 PM
Levon
Do a search. There are many Threads on doing this conversion and the required mods for the harnesses.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #5 of 15 (permalink) Old Nov 17th, 16, 3:39 PM
RonO.
Randy- is your dash aftermarket or OE? Does it have the seat belt warning light? Photos would help, what color are the characters on the gauges?
rattracer likes this.
1970 Chevelle 517 cid, TH400, best ET mid 9's. #19.
70SSTHUMPER is offline
post #6 of 15 (permalink) Old Nov 18th, 16, 8:55 AM
Darren
I've done it and it kind of sucked. I had to re-pin all about about 2 wires in the fuse box, but I was lucky and had a 70 ROUND gauge harness to go off of. I sat in the basement for about 3 hours and separated both looms completely. Ran each trace individually and tested everything several time before reconnecting to the car. Several people will tell you it can't be done because of all the changes to the dash harness in 72. I can be done, I've had a 72 dash in my car for 5 years now with not one issue.
Because I had no real use for the fasten seat belts light I turned it into a line lock light
If you want to PM me your email address, I still have most of the documentation used and I'll send it to you.
If you donít push the limits how are you going to find the weak spots?
USMC- Retired
My car: 1970 Chevelle
Factory 12 bolt /4-Speed Malibu -Dual stage wet nitrous with heater & purge - Holley Strip Dominator, Speed Demon 750 CFM - (All MSD distributor, blaster 3 coil, 6AL, & 3 stage retard) - 4 wheel disk brakes - Aeromotive Fuel system Ė Boss 338 18ís - BMW 5.25 true HID projector mod - and of course... the FLAPPER - bla, bla, bla.. lots of other expensive stuff I canít remember
70 nialator is offline
post #7 of 15 (permalink) Old Nov 18th, 16, 12:07 PM
I would sell your original 72 gauge harness and buy a correct used or new 70 gauge harness. Why mess up the 72 harness? There is a member on Team Chevelle who sells reconditioned and converted sweep dash harnesses. He could convert your sweep harness to a gauge harness. He could also sell you one ready to go. If you decide to convert your sweep harness on your own own, you will need to get a 12 pin connector to plug into the gauge cluster. I sell those if you will need one.
Here is a link to Dave the harness tweeker.
Team Chevelle Classifieds - 1970 CHEVELLE MONTE CARLO EL CAMINO TACH AND GAUGE DASH CLUSTER WIRING HARNESS OR RESTORATION SERVICES
RealRed70 is offline
post #8 of 15 (permalink) Old Nov 22nd, 16, 3:36 PM Thread Starter
Randy
Thanks for all the replies. I cleaned up the 72 dash, and repainted the black following a video I found online from Stacey David, the "gears" guy. I've got the three main gauges installed, still have the idiot lights for the three smaller gauges. I laid out the harnesses like you guys suggested. It doesn't look like there are that many difference, except for the instrument panel, like RealRed 70 says. Think I will give "Dave the harness tweaker" a shout before I go any further. Thanks again for all the advice.
post #9 of 15 (permalink) Old Nov 22nd, 16, 3:51 PM Thread Starter
Randy
Thanks Thumper. it is OE, got it from a guy for a couple hundred bucks, it is OE. Does have the seat belt warning light, and the gauges are white background with black characters. I know the 70s were green, but I'm going with white on this car. thanks again.
post #10 of 15 (permalink) Old Nov 22nd, 16, 3:54 PM Thread Starter
Randy
Thanks, Bart. Someone did a lot of work documenting that project, very helpful. The diagrams in the assembly manual are good, but they don't reference the color coding. I've printed out the stuff off your link, thanks!
post #11 of 15 (permalink) Old Jun 29th, 20, 12:33 AM
Rian
Hi Bart,
You did an excellent job of documenting your wiring harness schematics. I have a 1970 Malibu that the previous owner converted to an SS gauge type dash. I'm not sure whether or not he switched the wiring harness; but I would think that he had to do so in order for it to work properly.
I am changing my radio and noticed a black plastic wire connector, with only one terminal, hanging down under the dash to the right (passenger side) of the instrument cluster. It appears to be a part of the large group of wires that go to the fuse block; but it is very hard to see. This black plastic connector has only one terminal; yet has two wires, black with a pink or purple stripe and a brown, going in to it. It appears that the brown wire goes toward the passenger side of the dash, but I can't tell where it goes.
I have carefully reviewed your photos and schematics; in addition to several other wiring diagrams that I already had, and have not seen any reference to this connector. I can't even find a reference to a black wire with a purple or pink stripe on it. I tried to drag and drop a photo, but it didn't work.
Do you have any ideas?
Thank you very much. Rian
Chevelle Freak is offline
post #12 of 15 (permalink) Old Jun 29th, 20, 12:34 AM
Rian
Here is a photo of the wire connector.
Name:	Chevelle wire connector 4.jpg
post #13 of 15 (permalink) Old Jun 29th, 20, 6:38 PM
That connector is only used on cars with A/C. Does your car have A/C?
post #14 of 15 (permalink) Old Jun 29th, 20, 11:52 PM
Rian
It does not have A/C. Thank you so much for clarifying this issue. I am changing my radio and wanted to make sure that I didn't accidentally unplug this connector from the instrument panel. I appreciate it!
post #15 of 15 (permalink) Old Jun 30th, 20, 9:27 AM
You are very welcome.
