Bad alternator - Chevelle Tech
post #1 of 5 (permalink) Old May 18th, 05, 9:24 PM Thread Starter
Vince
Bad alternator
My friends t bucket is draining the battery overnight. I put a meter in line w/the negative cable, and theres a 350ma draw. If I disconnect the flat connector on the back of the alternator the draw stops. What do you think - bad alternator?
Vince
*69 SS 502 EFI /224* HR/9.8:1/T56/3.90 11.5/124mph
*11 C6, 6.2, 6spd
*96 Stang 6.0 turbo 10.5/135mph
*61" Scag Kohler 22hp 7mph
***In progress...04 Mustang, 454, TKO***
69-CHVL is online now
post #2 of 5 (permalink) Old May 19th, 05, 12:42 AM
Hey You!
Re: Bad alternator
I"d pull the alternator and have AutoZone check it.
Yo-ho Yo-ho a pirate's life for me.
John_Muha is offline
post #3 of 5 (permalink) Old May 19th, 05, 2:18 AM
Re: Bad alternator
Sounds like it to me.
Chris.
When the Boogeyman goes to bed, he checks the closet for Chuck Norris.
If it aint broke, just give me a minute.
Chris R is offline
post #4 of 5 (permalink) Old May 19th, 05, 11:52 AM Thread Starter
Vince
Re: Bad alternator
This unit has the stud on the back for the charge wire and a flat-blade connector. Does this make it a 3 wire alternator? Summit tech say just use a one-wire and disconnect the flat connector, but I dont know?
*11 C6, 6.2, 6spd
post #5 of 5 (permalink) Old May 19th, 05, 2:04 PM
Hey You!
Re: Bad alternator
That's a 3-wire. Made by Powermaster?? Should operate just fine as a 3-wire but if that alternator is being sold as a 1-wire, you can try what he said. Then I'd think I'd talk to the alternator company's tech reps.
This Thread is more than 5143 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Volts way out of line? driver Electrical & Wiring 29 May 10th, 03 9:37 PM
Installing 68 correct alternator. chattanoogachoochoo Electrical & Wiring 4 Apr 1st, 03 6:10 AM
Need a guru's help! CS-130 alternator wiring with idiot light rodneyaz Electrical & Wiring 6 Dec 6th, 02 9:46 PM
alternator and idiot light wiring clarktrip3 Electrical & Wiring 4 Jan 30th, 02 9:12 PM
Alternator repair questions kazuaki Electrical & Wiring 8 Mar 6th, 01 4:29 PM
