Voltage Drops to Zero When Starting - Chevelle Tech
post #1 of 5 (permalink) Old May 18th, 05, 4:04 PM Thread Starter
Hey all, I am having some problems on my 70 Malibu (SBC M20). I just replaced my old accel plug wires with Taylor Spiro Crimp-Yourself wires (the car has not run since replacing them). Also, the voltage regulator is less then a week old (voltmeter was jerking all over the place +/- several volts).
Since doing the plug wires last night I was not able to start the car. This battery has been in the car since I bought it last year, and it is a pretty plain looking one (no specs on the casing, no brand name...) and it has gone dead many times before. The only thing I have handy where I am is a booster pack from the local parts store that has also been around for some time (maybe 7 or 8 years). I tried starting it with it charged up over night, and the starter goes, but my voltage drops from about 12 volts right down to nothing. My voltmeter is hooked up to my ignition wire, so I am assuming that the spark plugs are not firing (with 0 volts) and that is why it won't start. Is this just a bad battery then? or is it something else? I jsut want to make sure it is the battery before buying a new one...
Thanks!
Brad is offline
post #2 of 5 (permalink) Old May 18th, 05, 5:28 PM
Re: Voltage Drops to Zero When Starting
If you could try jumping it with another car. Otherwise it sounds like the battery is gone. Batteries don't like being completely discharged several times.
John_Muha is offline
post #3 of 5 (permalink) Old May 19th, 05, 9:28 AM
Cool Re: Voltage Drops to Zero When Starting
When starting a car,battery voltage should not drop below 10 volts.Install a new battery and check your charging system!
Big Dre 72 is offline
post #4 of 5 (permalink) Old May 19th, 05, 9:48 AM
Hank
He said the starter is cranking, I think that's what he is saying, but the voltage at the ignition drops to 0. What does the voltage at the battery do while cranking? Sounds like it might be something else.
Hank
Finally is offline
post #5 of 5 (permalink) Old May 19th, 05, 12:06 PM
If you're talking about the voltage on the gauge and not on the battery, I'd check the battery connections and the ground to the engine first of all. But it could just be an old battery.
1969 Malibu in progress
Olle is offline
This Thread is more than 5261 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Starting Woes - Saga Never Ends! sarblade Electrical & Wiring 6 Aug 21st, 04 1:10 AM
starting voltage drop 70SS540 Electrical & Wiring 2 Jul 9th, 04 10:20 AM
Procedure for finding voltage drop? NoDakSS Electrical & Wiring 3 Jul 1st, 04 3:20 PM
Voltage Regulator Clicking, No Starting???? OrrieG Electrical & Wiring 3 Sep 2nd, 02 8:35 PM
Can I reduce voltage to electric cooling fan to reduce noise?e Joel Koontz Electrical & Wiring 4 Feb 11th, 01 6:54 AM
