starting problems - Chevelle Tech
post #1 of 3 (permalink) Old May 18th, 05, 8:45 AM Thread Starter
Send a message via AIM to ed3196499 Send a message via Yahoo to ed3196499
Unhappy starting problems
My 64 has been giving me some starting problems I thought they were just from the car sitting for a while but today I drove it 70 miles to work (volt gauge read good all the way) and still have the same problem. The car will start cold no problem but if I have to shut her down it wont barely turn over like the bat is dead. I have a battery mounted in the trunk which runs up to a ford solenoid mounted on the fender well down to the starter. I have added the solenoid in the last year which really helped my hot starting issues from before, now this new problem is similar but I cant understand what is causing it. I am thinking the starter is going out on me does that sound about right? I had this first happen when I went to the store shut it down and came out 5 minutes later and the car wouldnt start. I got a person to give me a jump but it wouldnt work, after about a half hour of sitting and another jump she fired right up.
U.S. Coast Guard, BMC
1970 Chevelle, 307
2004 Ford F250, Crew Cab, 4x4, 6.0 Powerstroke
2005 Harley Sportster 1200C
2006 Chevy Impala
ed3196499 is offline
post #2 of 3 (permalink) Old May 18th, 05, 9:38 AM
Re: starting problems
After having the same problem with my 454 with battery in the trunk, I broke down and bought the mini starter that jegs has on sale. Turns over great now hot or cold. You could check the engine and battery ground, make sure wire to the front is big enough. Its sounds like heat soak or inital timing too high. Mark
73camaro is offline
post #3 of 3 (permalink) Old May 18th, 05, 9:42 AM Thread Starter
I thought it might have been the timing too but I messed with it and still have the same problem, when I first fire it up it turns over strong.
1970 Chevelle, 307
2006 Chevy Impala
This Thread is more than 5498 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Problems with crashing/corruption. Moloko Bug Hunt 10 Jan 26th, 05 12:37 PM
hard starting problems Tom G Troubleshooting 7 Aug 9th, 04 12:29 AM
67 Still Having Start Problems sarblade Electrical & Wiring 1 May 20th, 04 8:14 AM
starting problems FUELS94 Electrical & Wiring 8 Oct 24th, 02 1:58 AM
Starting Problems wanarace Electrical & Wiring 14 Sep 30th, 00 4:07 AM
