battery dies but alternator is good - Chevelle Tech
post #1 of 4 (permalink) Old May 18th, 05, 12:38 AM Thread Starter
I posted a week ago that my battery dies, I took my alternator out and had it tested and its good. What could be wrong? Does something have a bad ground and its draining my battery? Just need some help!
pro785racr is offline
post #2 of 4 (permalink) Old May 18th, 05, 1:03 AM
Troy
Re: battery dies but alternator is good
Unless you've converted to a single wire, you might check the external regulator. Same thing happened to mine, alternator turned out OK but it wasn't charging.
1972 Chevelle SS LS3
SuperChevy402 is offline
post #3 of 4 (permalink) Old May 18th, 05, 10:18 AM
Try disconnecting the negative cable from the battery. Put a test light between the negative cable and the negative post of the battery. See if the test light comes on. It should not light up unless you have a clock or a modern radio memory.
John_Muha is offline
post #4 of 4 (permalink) Old May 18th, 05, 5:44 PM Thread Starter
yes i have a modern stereo in there, where is the voltage regualtor, the alternator is kind of new and i thought it would have an internal one.
This Thread is more than 5497 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
A good performer Battery.... feedphillipnow 2005 24 May 14th, 05 1:29 PM
How to use the battery clamp? jgoggan Chevelle Tech 9 Apr 29th, 05 1:53 PM
battery dies/ gen light stays on? 69chevelle355 Electrical & Wiring 4 Nov 30th, 04 1:45 PM
Battery cut-off - Good way to stop theft? Shawn 2001 7 Aug 13th, 01 11:01 AM
battery dies cub 2001 2 Aug 4th, 01 4:57 PM
