Starter: Engine turns over a few then squeels - Chevelle Tech
post #1 of 3 (permalink) Old May 17th, 05, 8:37 PM Thread Starter
The other day I turned the key and it started turning the engine over a few revs then started skwakin and squeelin. Let off key, turn again..... few revs just fine as day, then the noise. This is all out of the blue, now it happens every time I start. Sometimes I don't get the starter to turn over at all. Sometimes it it spins up fine, and others it spins fine then squawks.
Cables look good, how do I tell if they are bad? Had the battery tested and it puts out some 780cca.
Had the starter rebuilt, it's a gear reduction. Same problem.
Lights never dim or anything driving wise, so I assume the alternator is good.
The teeth I saw on the flexplate looked good, and looked great when I had the trans out only 1000miles ago.
Any ideas?
Twilightoptics is offline
post #2 of 3 (permalink) Old May 18th, 05, 10:09 AM
Re: Starter: Engine turns over a few then squeels
Sure it's coming from the starter?
John_Muha is offline
post #3 of 3 (permalink) Old May 18th, 05, 8:47 PM Thread Starter
Positive. Starter/flywheel. Today it's been turning the engine over for like 2 seconds, and right before or right as it goes to fire the starter disengages and squeels for a second, then goes again if I don't let off the key.
Battery cables and posts are new, replaced those yesterday.
This Thread is more than 5240 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
327 rocker adjustment green65 2001 8 Jun 2nd, 06 5:44 PM
Help!!!...Can a low battery kill my starter???? LXS 2004 10 May 29th, 04 3:27 PM
installing engine - please HELP! New68SS 2004 6 Jan 28th, 04 6:23 AM
Shimming Starter rednecks70 Troubleshooting 2 Jun 18th, 03 12:20 PM
Engine bogs under heavy braking or low rpm heavy turns, what is wrong? Stikman33 2002 10 Nov 1st, 02 12:01 PM
