wiper switch problems - Chevelle Tech
post #1 of 4 (permalink) Old May 14th, 05, 7:21 PM Thread Starter
Hey guys, The wiper switch in my 64 gets warm to the touch any time the ignition is on. I've run the extra ground from my cluster to the parking brake so I should have good ground. The wipers work correctly, just can't figure out what is producing heat in the switch, any ideas?
natjones is offline
post #2 of 4 (permalink) Old May 14th, 05, 9:35 PM
Re: wiper switch problems
When the wipers are turned off?
post #3 of 4 (permalink) Old May 14th, 05, 10:03 PM Thread Starter
yes, even if the wipers are not turned on the switch will get warm.
natjones is offline
post #4 of 4 (permalink) Old May 14th, 05, 10:08 PM Thread Starter
A lttle more info, the wiring harness is not original, it has an aftermarket style harness with modern fuses, not sure which brand because it was installed when I got the wagon.
natjones is offline
This Thread is more than 5534 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
71 harness to a 72 wiper switch MATHER34 Electrical & Wiring 4 Apr 23rd, 04 7:22 AM
Wiper Switch function SPDJeff Electrical & Wiring 1 Jan 21st, 03 9:27 PM
How to check if a wiper switch (type C motor) is working mike69ss Electrical & Wiring 1 Jan 11th, 03 9:20 PM
windshield wiper problems bhawk Electrical & Wiring 9 May 22nd, 02 3:58 PM
Wiper switch / motor meltdown JodySirmans Electrical & Wiring 5 Apr 25th, 02 9:48 AM
