Ground straps - Chevelle Tech
post #1 of 5 (permalink) Old May 14th, 05, 12:31 PM Thread Starter
Bart
Question Ground straps
69 Chevelle, the assembly manual shows two ground straps going from the valve covers to the fire wall, are both the straps needed? What is the need for two? I have none on right now and the car (stock) seems to run fine all lights work (dash and exterior)
Bart
surmin69 is offline
post #2 of 5 (permalink) Old May 14th, 05, 12:58 PM
Re: Ground straps
I've heard that the ground straps are for radio noise supression. You probably have a cable from battery negative to the engine. That's the electrical ground. It's also important to have a multi-point ground for the engine block to the frame. I've studied this setup and it looks like GM wanted the block grounded in more the one place to act like shield for the ignition system getting into the radio.
Almost original owner of '72 Elky SS - 415cu Motown, Stealth Ram EFI, AFR 210's, Hyd. Roller;
Baer 13" discs front/rear, 17" x45ZR tired "Grocery Getter" - I will get thing painted if it kills me...
-- also an '87 German Corvair (Carrera Targa - "The Heartbeat of Germany")
docaudio is offline
post #3 of 5 (permalink) Old May 14th, 05, 6:56 PM
Hank
Re: Ground straps
Yes the 2 braided ground straps are for radio noise interference. I think there are actually 3, or maybe that that's only if you have an FM radio which is more sensitive to electrical noise. The engine gets it's ground from the main battery negative cable. The rest of the electrical system gets it's ground from the ground wire to the passenger side front fender. They're not required unless you want the car to look 'correct' or are experiencing noise in the radio. Most modern radios have noise suppressers built in.
Hank
Finally is offline
post #4 of 5 (permalink) Old May 14th, 05, 8:37 PM Thread Starter
Bart
Smile Re: Ground straps
Thanks for the info guys
Bart
surmin69 is offline
post #5 of 5 (permalink) Old May 14th, 05, 11:45 PM
Re: Ground straps
Should also be one from frame to body, right front about where passenger floor board is.
69ssmike is offline
This Thread is more than 5501 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
ground straps (wires) stroobydoo Electrical & Wiring 8 Feb 15th, 04 5:29 PM
1966 ground straps pur66msl Restoration Corner 2 Sep 26th, 03 3:06 PM
Two Ground Straps at firewall ('69 BB) Flye Electrical & Wiring 4 Nov 25th, 02 9:15 PM
ground straps papaflacko Electrical & Wiring 15 Jul 18th, 02 8:11 AM
Ground Straps mikeschevelle Electrical & Wiring 6 May 28th, 01 5:38 PM
