Diodes? - Chevelle Tech
post #1 of 5 (permalink) Old May 12th, 05, 8:28 PM Thread Starter
Send a message via AIM to onick
Diodes?
was looking for diodes to give my relays longer life for my 2 speed taurus fan. I picked up some 3 amp 400PIV rectifier diodes, will these work? The part # 1n5408 was not availiable so i got the 1n5404. will these be ok?
Eric Onick
1968 Chevelle Malibu
Big Block-475ci built by Mark Jones
Tremec TKO-600 5-speed
12 bolt Eaton Posi
TC Member# 2320
onick is offline
post #2 of 5 (permalink) Old May 12th, 05, 9:32 PM
Hank
Re: Diodes?
The 1N5408 has a higher PIV and same amp rating. I can't see those fans when free wheeling generating more or even close to the 400 PIV the 1N5404 is rated for. They should work fine.
Hank
Finally is offline
post #3 of 5 (permalink) Old May 12th, 05, 9:45 PM Thread Starter
Re: Diodes?
Thanks man
Eric Onick
12 bolt Eaton Posi
TC Member# 2320
onick is offline
post #4 of 5 (permalink) Old May 13th, 05, 7:34 AM
Hank
Re: Diodes?
Sorry, I was thinking backwards when I replied. The fans won't create inverse voltage when free wheeling, they'll create forward voltage. The diodes will allow the voltage through, essentially shorting out the fan. Doesn't matter, the current rating of both diodes is 3 amps. That's what matters in this case not the PIV.
The PIV has to be high enough to withstand the voltage applied to the fan when the relay is on, which is only 12v. With a PIV of 400v those diodes should be good.
Just wanted to clarify that.
Hank
Finally is offline
post #5 of 5 (permalink) Old May 13th, 05, 11:31 AM Thread Starter
Re: Diodes?
even better
Eric Onick
12 bolt Eaton Posi
TC Member# 2320
onick is offline
This Thread is more than 5492 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Battery drain after engine swap 69-CHVL Troubleshooting 19 Sep 13th, 04 4:16 PM
For Bill K oman 2003 12 Aug 23rd, 03 4:04 PM
Help! Which diodes go where?? snydes Electrical & Wiring 2 Jun 12th, 01 6:37 PM
Factory tach problems stevenb8 1999 -- 1 Jan 21st, 00 9:13 AM
