70 SS 396 Won't Start - Page 2 - Chevelle Tech
post #16 of 18 (permalink) Old May 15th, 05, 4:24 PM Thread Starter
Re: 70 SS 396 Won't Start
OK, I'll get that wire replaced. As for the one coming off the starter, you say I don't need a wire going from starter to distributor? Or did I misunderstand that?
Also, I have discovered a thin, blue wire with a small rubber 'boot' looking thing on the end. It was just laid over behind the master cylinder. Any idea what in the world that might go to?
ejrobert is offline
post #17 of 18 (permalink) Old May 15th, 05, 7:12 PM
Originally Posted by ejrobert
I parked it in the garage, running fine. Next day, it won't run. When I turn the ignition to the 'start' position, it fires up. But when I let the ignition key go to the 'run' position, it dies. I can even rev the engine a time or two with the key in the 'start' position, but it dies immediately when I let it go to 'run'. I have checked the fuel pump, and the carb is getting PLENTY of gas. I have replaced the ignition switch, still no joy. I'm pretty much at the end of my (very) limited experience, so if one of my fellow Chevelle owners can give me a hand with this, I'd certainly appreciate it.
Let's see...battery is new and full of juice, it has a new Mallory HEI, new plugs and wires, all fuses appear to be good, and a new ignition switch. Any ideas?
I'm almost ashamed to tell this one, but I had that happen last summer after installing a ZZ502. Of course the 502 is not machined for a mechanical pump, so I had to go with an electric. Rather than run the lead from the pump to the ignition, I ran it to the solenoid on the starter. When I'd hit the ignition, she'd fire until the solenoid released.....then die.
L34 Chevelle is offline
post #18 of 18 (permalink) Old May 15th, 05, 7:17 PM
Angry Re: 70 SS 396 Won't Start
I'm almost ashamed to tell this story........but i installed a ZZ502 in mine last summer. Of course, the 502 is not machined for a mechanical pump, so I mounted the electric and ran the lead to the solenoid, rather than to the ignition. She'd run until the solenoid released, then quit.
This Thread is more than 5501 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Expanded "Basics of Basics" Inverted welding MARTINSR Body Shop 13 Dec 17th, 05 2:59 PM
not start when hot please help 68chevelle8111112222 Electrical & Wiring 19 Apr 19th, 04 11:31 AM
car won't start after a few days lita Troubleshooting 3 Feb 3rd, 04 8:18 PM
Rebuilt High performance 350 wont start? chevelle_malibu18 Troubleshooting 3 Oct 1st, 03 1:42 PM
ENGINE WON'T START 2 Pres'67chev 2002 2 Dec 7th, 02 10:12 PM
