64 wagon sending unit - Chevelle Tech
post #1 of 3 (permalink) Old May 10th, 05, 3:07 AM Thread Starter
Hey guys, I originally posted this in the wagon section but didn't get a response. Will the standard reproduction 64 fuel sending unit fit a wagon or are the wagon units different? I know that the 64 uses a lower ohm unit than 65-72, Year One lists a 64 sending unit while most other suppliers including Ground Up don't seem to, they show a 64-67 unit. No one that I've found actually lists a sending unit for a 64 wagon. Does anyone repro the wagon unit if they are different. Thanks Guys!
Nat
68 SS396 Convertible-396/4speed
68 SS396 Hardtop-396/auto
64 2 Door Wagon- 350/auto
46 chevy pickup- chopped hot rod
natjones is offline
post #2 of 3 (permalink) Old May 10th, 05, 8:11 AM
Re: 64 wagon sending unit
Yes the 64 wagon unit is different from the El Camino or Malibu/300. I dont know of a source for the wagon sending unit.
TC member 368
Elree Colby is offline
post #3 of 3 (permalink) Old May 10th, 05, 10:08 AM
Hey You!
I used a 65 sender in my 64 (0-90 ohms). Wanted one with a 3/8 outlet instead of the 5/16 outlet and couldn't find a 64 sender like that at the time. What I did was hang a 39 ohm 10 watt resistor between the sender wire and ground on the back of the gage. It doesn't work perfectly but does give a close enough reading to let you know when you are running out of gas.
Yo-ho Yo-ho a pirate's life for me.
John_Muha is offline
This Thread is more than 5180 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Smoking and always rich SteveRoehll Troubleshooting 12 Apr 9th, 08 8:30 AM
64 wagon sending unit HELP natjones Wagons & Four Doors 1 May 11th, 05 12:05 PM
wagon fuel sending unit B/B J_Fairchild Wagons & Four Doors 10 Mar 7th, 05 7:17 PM
defective gas gauge sending unit ? il69smbk48 Electrical & Wiring 3 Oct 24th, 04 9:01 PM
Oil Pressure Sending Unit Does Not Fit?? Xtreme70SS396 2002 6 Feb 24th, 02 9:38 PM
