Mallory HEI Hook Up - Chevelle Tech
post #1 of 6 (permalink) Old May 9th, 05, 8:55 PM Thread Starter
Mallory HEI Hook Up
Converting small block to big block in 72 Malibu. 509 Merlin with Mallory 8548201C HEI distributor. There is one set of wires with terminal plug ging from the distributor base to the coil cap housing. There is also a place for another terminal plug..labeled-coil, ground, battery. Where do I get this terminal plug and how does it need to be connected to from my original stock wiring ?
Thanks in advance.....1972 Chevell newbie
FOSS is offline
post #2 of 6 (permalink) Old May 9th, 05, 9:32 PM
Re: Mallory HEI Hook Up
theres a harness and plug that comes from the dist base, that plugs into the dist cap recess closest to the cap-theres 2 more places in the cap that is in front of the before mentioned plug-the one on the left is for the tach, the one on the right is +12 volts-find the orig wire that feed your coil, its kind of a white cloth covered wire(the yellow one comes from the starter-you wont need it)-its a resistor wire, designed to drop voltage from +12 to around 8-9v-follow it down to the firewall plug-you want to replace this with a reg wire-they sell a replacement wire with correct ends from year one, L00510, and it plugs right into your harness and dist-i just got one and it works out good-i have made my own before, but always nicer if its done
when your credit cards are maxed, have the limits raised
forcd ind is offline
post #3 of 6 (permalink) Old May 10th, 05, 7:38 AM Thread Starter
Will be calling Year One today...this website and it's members are a big help !!
FOSS is offline
post #4 of 6 (permalink) Old May 10th, 05, 8:01 AM
I think if you replace the resistor wire by a " standard " wire, you have to use a ballast resistor with mallory hei.
Davidmalibu is offline
post #5 of 6 (permalink) Old May 10th, 05, 12:47 PM
Hank
I think that's if you use the Mallory Unilite, a points conversion module. The number he listed is a full HEI coil in cap distributor.
Hank
Finally is offline
post #6 of 6 (permalink) Old May 10th, 05, 2:50 PM
right, it's for unilite
This Thread is more than 5299 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
HEI Distributor - Which is terminal 1? az_chevelle 2005 2 Apr 15th, 05 3:44 PM
HEI vs stock ignition on a 67 northern 396 2005 5 Apr 15th, 05 2:17 PM
GM HEI Problems: I kill iginitions... 65 GTO Electrical & Wiring 12 Apr 14th, 05 4:51 PM
Mallory Rev Limiting HEI Distributors- Finally! RobbMc 2004 15 Apr 19th, 04 12:30 AM
Mallory Unilite Conversions and Battery Tenders Ken's Email 2003 3 Sep 4th, 03 2:57 PM
