64 ignition cylinder problem - Chevelle Tech
post #1 of 3 (permalink) Old May 8th, 05, 12:11 PM Thread Starter
Hey guys, I replaced the ignition cylinder in my 64 wagon in the hopes that it would stop you from being able to start the car without the keys, it didn't. I guess I neeed to replace the ignition starter switch, will that remedy my problem? Thanks in advance
natjones is offline
post #2 of 3 (permalink) Old May 8th, 05, 2:14 PM
Re: 64 ignition cylinder problem
There is a "lock" position on the switch. If you use that, you need the key to get back out of lock. Unless your tumblers are worn out, then it's time for new tumblers.
MedicTed is offline
post #3 of 3 (permalink) Old May 8th, 05, 7:38 PM Thread Starter
Thanks so much, Now I feel like an idiot!!! I've been messing around with chevelles for a good many years (mostly 68-72), I can't believe I didn't know that.
natjones is offline
This Thread is more than 5545 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
ignition switch problem? [maybe] yellowcar72 Electrical & Wiring 5 Jul 20th, 04 4:08 PM
Possible Ignition Problem? Doublexx Electrical & Wiring 1 Jan 10th, 03 3:56 PM
Ignition wiring problem fmss4 Electrical & Wiring 4 Nov 24th, 01 8:11 PM
Will 6V or Ground on MSD 6AL ignition wire burn it out? rcollette Electrical & Wiring 6 Nov 16th, 01 7:58 AM
Ignition Lock Cylinder Install??? JeffK 2000 9 Nov 17th, 00 9:02 PM
