testing a Charge.... 67 SS - Chevelle Tech
post #1 of 5 (permalink) Old May 7th, 05, 8:39 PM Thread Starter
wes
Where do I put my voltage gauge to test if the 396 is charging? I just have the simple tester that has about 20-30 setting and a black and red wires, will this work? I recently put another voltage regulator on it and hoped it fixed the charging problem.
Thanks TEAM CHEVELLE!
wes
Wes B in utah
warmed over stock black 67 SS clone
4 Speed butternut yellow 67 SS project
67Chevelleguy is offline
post #2 of 5 (permalink) Old May 7th, 05, 8:46 PM
Re: testing a Charge.... 67 SS
Black on neg. battery cable and red on pos. cable or large hot wire on back of alternator.
Should show somewhere around 14 volts
post #3 of 5 (permalink) Old May 7th, 05, 10:25 PM Thread Starter
wes
while the car is running? I am trying to test if the Alt. is charging the batt.
thanks,
wes
Wes B in utah
post #4 of 5 (permalink) Old May 7th, 05, 10:36 PM
thanks,
wes
Thats correct Wes, you should see around 14 volts on the bat posts while the engine is running.
Chris.
When the Boogeyman goes to bed, he checks the closet for Chuck Norris.
If it aint broke, just give me a minute.
Chris R is offline
post #5 of 5 (permalink) Old May 7th, 05, 11:14 PM
Allen Carson
Smile Re: testing a Charge.... 67 SS
What I did was to install a mechanical set of gauges.Volt meter -oil gauge-and Temperature gauge. They work much better than stock.
al carson is offline
This Thread is more than 5219 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Doesn't keep a charge... 67Chevelleguy Troubleshooting 6 Apr 14th, 05 9:46 AM
Not keeping a charge... 67Chevelleguy Troubleshooting 2 Jun 9th, 04 5:48 PM
What to charge a friend??? ss396boy Body Shop 31 Oct 11th, 03 7:35 PM
