Headlights on all the time - Chevelle Tech
post #1 of 8 (permalink) Old May 7th, 05, 3:02 AM Thread Starter
All 4 headlights go on as soon as I connect the battery, Ignition off, lightswitch off. HELP!
Frank1 is offline
post #2 of 8 (permalink) Old May 8th, 05, 9:53 AM
Re: Headlights on all the time
Tried pulling the connector off the headlight switch?
John_Muha is offline
post #3 of 8 (permalink) Old May 8th, 05, 11:56 AM Thread Starter
yes its a new switch. still on.
Frank1 is offline
post #4 of 8 (permalink) Old May 8th, 05, 11:20 PM
So with the headlight switch connector hanging in the air, all four headlights are still on?? I read that correctly?
post #5 of 8 (permalink) Old May 9th, 05, 2:49 PM
That's a neat trick. Can you say "maybe wired wrong" boys and girls.
Herb Sr
'67 Coupe (frame-off)
489BB Full Roller Stroker
M20/3.73 Eaton posi
Herb is offline
post #6 of 8 (permalink) Old May 9th, 05, 4:53 PM
Just a thought: Have you connected the switch, but haven't got the knob on there yet? If you have the knob removed, the switch will be in the "on" position.
1969 Malibu in progress
Olle is offline
post #7 of 8 (permalink) Old May 15th, 05, 12:31 AM Thread Starter
Yes Olle the knob is on, it cant be wired wrong its all plugs and their all pluged ih where they go. I'm gettin a 12 volt feed directly to the lights bypassing the switch but I cant find it.
Frank1 is offline
post #8 of 8 (permalink) Old May 15th, 05, 12:57 AM
So, did you try what John suggested ??
This Thread is more than 5502 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Break in procedure, after initial start up?? driverk 2002 16 Jul 24th, 06 9:46 PM
Used Welders -- What to Look For hd99fxst Body Shop 6 Jul 5th, 05 9:13 PM
Quarter Mile time with CompCam 274 XE update Spawn22 2004 21 May 21st, 04 9:46 PM
New Time slip 67 chevelle 274xe cam Spawn22 2004 23 May 18th, 04 11:16 PM
headlights delay turning on about 10 seconds? cperrell Electrical & Wiring 4 Oct 16th, 03 1:42 PM
