Battery in trunk/Disconnect switch - Chevelle Tech
post #1 of 3 (permalink) Old May 3rd, 05, 4:54 PM Thread Starter
I am going to be mounting the battery in the trunk on my chevelle. I plan on racing it eventually so i guess i will need to have a disconnect switch.
What kind of switch will I need? It sounds like you have to disconnect the battery and the alternator to kill the motor. Do I run the alt to battery wire all the way to the back of the car to the switch? Or is there a better way to do this? Also, what disconnect switch do you guys reccomend?
Danny
http://www.cardomain.com/id/hockey8720
Hockey8720 is offline
post #2 of 3 (permalink) Old May 6th, 05, 4:28 PM Thread Starter
Re: Battery in trunk/Disconnect switch
Nothin huh?
well i go the 4 pole moroso switch. do i have to run the alt->bat wire all the way back? it seems like i would have to run a pretty large wire for that distance...
Danny
post #3 of 3 (permalink) Old May 17th, 05, 7:33 PM
I put a junction block in the front of my car in the inner fenderwell. I ran a 0 gauge wire up along the frame to the junction block. Then ran the alternator and starter wires from there. I got the block from http://www.delcity.net/.
Tim
TimG is offline
This Thread is more than 5270 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Flaming River Battery Cut Off Switch Mounting Ideas for a 70-72 Chevelle............ Rumblin70SS 2005 3 Mar 30th, 05 5:38 PM
Battery ON/OFF switch T Man 2004 9 Sep 29th, 04 10:19 AM
Trunk Battery with Disconnect Switch Ron_Long Electrical & Wiring 12 Sep 6th, 04 4:31 PM
battery disconnect switch dusted800 Electrical & Wiring 5 Apr 26th, 03 12:56 PM
Getting ready for the track, question re Battery Kill switch yanniz 2002 9 Apr 24th, 02 12:30 AM
