Everything stays on when key is off? - Chevelle Tech
post #1 of 5 (permalink) Old Apr 29th, 05, 6:56 PM Thread Starter
Unhappy Everything stays on when key is off?
Hi all, I was wondering if any one has a clue why everything in my 69 malibu 350, stays on after the key is off. I wouldn't mind a couple of suggetions so I can start ruling them out or investigate further. I am new to this forum So thanks in advance for all your wisdom. negra chevella
negra chevella is offline
post #2 of 5 (permalink) Old Apr 29th, 05, 8:40 PM
Re: Everything stays on when key is off?
Could be the ignition switch adjustment. The key unlocks the steering column and positions the ignition switch that is mounted on top of the steering column. It's possible to have the lock in the off position but the switch not quite in the off position.
TC member 368
Elree Colby is offline
post #3 of 5 (permalink) Old Apr 30th, 05, 8:15 AM
Well......do you mean it "runs-on" then quits...or runs and you have to pull the battery or coil wire to get it to stop? Big difference in where to look!!!
I am assuming the later. If this is the case let me ask you a few questions. Have you changed anything electrical including working on the starter? Which coil set-up do youhave.....stock or HEI? Usually what happens is that either someone hooks up an full time DC feed to the ignition or the ignition switch is bad or misadjusted. I have seen this where the ignition switch (on the bottom of the steering column) was loose or broken. Also, what do you still have the old style coil in? The feed from the starter R terminal can be the source sometimes either laying onthe positive terminal or mistakingly hooked there.
A quick check is to measure the voltage at the coil with the key off. If there is DC there...then find where it's coming from. Get a schematic and go for it.
Steve "Jack'stands" Jack
HOTRODSRJ is offline
post #4 of 5 (permalink) Old May 8th, 05, 1:29 PM
hey what type of ignition set up do u have? if its an msd, i had the same problem. There is a mini capacitor that you you can put in line to your alternator o prevent a current from constantly going through the system
19marc72 is offline
post #5 of 5 (permalink) Old May 8th, 05, 8:02 PM
Steamy
Originally Posted by 19marc72
mini capacitor
I believe it's called a Diode-not a mini capacitor. A diode is like an electrical check valve--current can only flow in one direction.
BL
My Showroom
Ark68SS is offline
This Thread is more than 5217 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Harmonic balancer/crank key question Junkyard Dawg 2005 4 Apr 13th, 05 10:08 PM
key warning switch hrd Electrical & Wiring 0 Apr 13th, 05 8:33 PM
red brake light stays on 71 Chevelle Ronald M. Roberts Brakes, Suspension & Steering 4 Apr 5th, 05 3:24 PM
battery dies/ gen light stays on? 69chevelle355 Electrical & Wiring 4 Nov 30th, 04 1:45 PM
dash brake light stays on? 19733 Electrical & Wiring 2 Nov 6th, 04 9:14 PM
