alternator question - Chevelle Tech
post #1 of 3 (permalink) Old May 12th, 16, 3:34 PM Thread Starter
Paul
alternator question
See the pic. My alternator has what I think is a regulator mounted on the top of it. See the red wire going to the post. There's also a plug from this that can go into the alternator. The wire from the wiring harness also has a plug on it, visible in the pic. I can't remember which plug was used when I pulled the alternator a while back. I do recall the red wires from both the harness and small mounted box went to the same post on the alternator.
Tried to attach a pic, hope it worked
Paul J
'69 El Camino SS
396 CI,Hooker Super Comps
TH400, HEI, Performer Intake, 750 cfm
Paul J is offline
post #2 of 3 (permalink) Old May 12th, 16, 5:32 PM
Re: alternator question
It looks like a previous owner got creative with the wiring. I would trace those wires back and see where they go. Does the car have a voltage regulator mounted on the radiator support? If the terminals in the alternator are arranged like =, it is an externally regulated alternator. If they are like this _ _ then it is externally regulated. I suggest making sure that the braided stainless hose is kept far away from that stud where the red wire goes.
JWagner is offline
post #3 of 3 (permalink) Old May 12th, 16, 7:45 PM
I bet its one of these or sililar:
Part # D7024 - Conversion Voltage Regulator 12 Volt, B-Circuit, 14.2 Voltage set point. For: Universal Design
oldcutlass is offline
This Thread is more than 1133 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
