Gas gauge reads too high - Chevelle Tech
post #1 of 4 (permalink) Old May 11th, 16, 4:39 PM Thread Starter
I have a '72 model that has been sitting for a long time. I started it up and noticed that the gas gauge went immediately to above the FULL mark. What could that be caused by?
JWagner is offline
post #2 of 4 (permalink) Old May 11th, 16, 4:53 PM
Re: Gas gauge reads too high
I would check the connections at the tank - particularly the ground. After sitting for a while, you may have a dirty connection. I may have this backwards, but I believe the gauge reading full is an open circuit where as complete ground would read empty. Anything in between is based on the resistor on the float.
jim
Jim's69Ragtop is offline
post #3 of 4 (permalink) Old May 11th, 16, 5:11 PM
Randy
jim
Approximately 90 ohms from tan sending wire to ground is a full tank, zero ohms to ground is empty. Anything much above 100 ohms will peg the gauge beyond full. I agree, an open ground at the tank or the gauge is usually the problem, but the resistance element in the sender or the gauge itself could also be defective. This guy shows how to troubleshoot all parts:
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #4 of 4 (permalink) Old May 11th, 16, 5:44 PM Thread Starter
I am thinking evil thoughts here. I may have some wires chewed through by pack rats, as there is one turn signal/brake lamp that is also out.
JWagner is offline
This Thread is more than 1383 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
