Ignitor II and Flamethrower II install (HELP) - Chevelle Tech
post #1 of 7 (permalink) Old May 8th, 16, 8:31 PM Thread Starter
Joe Trav
Thought this was going to be relatively easy the way Pertronix explained it. I have a 1968 Chevelle 307 cui with point type ignition,
Removed the coil resistor wire and yellow wire coming from solenoid.
Removed points and condenser. Installed module from Ignitor II as
directed did have to install shim washer provided to close the gap between Mag ring and module to 0.050". I ran a bypass 12 awg wire
from the Ign. terminal in my fuse block to the + side of the coil along with the red wire from module and black wire to - side of the coil.
tucked the resistor and yellow wire from starter away out of sight.
Thought all was good hooked up the Battery Turns over won't run.
What am I missing?
magnet is offline
post #2 of 7 (permalink) Old May 8th, 16, 9:43 PM
Re: Ignitor II and Flamethrower II install (HELP)
On my 68 SS 396 I did the same as you when I installed a Pertronix 3. Engine turned over but wouldn't start. I had to reinstall the yellow wire from the starter back to the coil. The 12 awg wire from the IGN spade wasn't providing a full 12 volts. Hope this helps.
Bill B.
billbonn80 is offline
post #3 of 7 (permalink) Old May 8th, 16, 11:52 PM Thread Starter
Joe Trav
Thanks Bill I"ll try it, did you have to change anything with the ignition switch?
magnet is offline
post #4 of 7 (permalink) Old May 9th, 16, 3:14 AM
Nothing was changed on the ignition switch. It turns out after research and help from forum members that the Ign spade that your running your 12 volts through to the coil doesn't give a full 12 volts while cranking. I confirmed this with a meter. Once I reinstalled the yellow wire it worked fine and I haven't had any problems related to that. Hope this helps.
Bill B.
post #5 of 7 (permalink) Old May 9th, 16, 9:37 AM
You can confirm this by checking voltage at your coil+ terminal in both start and run ign key positions.
oldcutlass is online now
post #6 of 7 (permalink) Old May 9th, 16, 12:27 PM Thread Starter
Joe Trav
Thank you ...will give it a shot after work.
magnet is offline
post #7 of 7 (permalink) Old May 9th, 16, 8:18 PM
Rob
This probably wouldn't be an issue if the stock wiring system didn't have such a huge voltage drop from the battery to the fuse panel.
My build thread>
65chevelle300post is offline
This Thread is more than 1525 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
