Installing extra "ign" terminals? - Chevelle Tech
post #1 of 14 (permalink) Old May 5th, 16, 9:25 PM Thread Starter
The "ign" terminal in my '69 Malibu is getting a bit crowded, so I thought it might be a good idea to install an extra fuse box with separately fused terminals. Got the ignition hooked up to it, and I don't want the engine to die if something else blows the fuse
Haven't really thought much about what to use, where to put it etc, but the first thing on the agenda is to figure out where to pick up switched 12V. What would be the best place?
1969 Malibu in progress
Olle is offline
post #2 of 14 (permalink) Old May 5th, 16, 9:44 PM
Re: Installing extra "ign" terminals?
I think you'll still need to get this off of the existing IGN circuit since it comes from the key switch. What you could do is use that to power a relay that then supplies power to an additional fuse box wired off the battery. Similar to how some have run their headlights directly off the battery, with the light switch only carrying a small amount of current to close the relay.
jim
Jim's69Ragtop is offline
post #3 of 14 (permalink) Old May 5th, 16, 9:57 PM Thread Starter
jim
That's a pretty neat idea. I don't want to cut or splice any wires (the original wiring is in perfect condition), so a relay would be a good way to tap some extra juice "straight from the source".
Any other ideas?
Olle is offline
post #4 of 14 (permalink) Old May 6th, 16, 11:45 AM
Bryan
I did something similar when I rewired my Falcon based Ranchero.
To take the load from the ignition switch, the Ignition buss and the Accessory buss are triggered by relays.
Nothing but the coil and a couple of relays are tied to the ignition switch.
Use your existing IGN port to power the coil on a relay to a remote buss or fuseblock
Bryan's toyz
66 ElCamino 3oh7/TKO 5spd (mousey) Almost done
On the street now!!!
Bryan59EC is offline
post #5 of 14 (permalink) Old May 6th, 16, 11:50 AM
Good advice, using relays.
post #6 of 14 (permalink) Old May 6th, 16, 8:43 PM Thread Starter
I might be overly cautions, but would it be a good idea to put an inline fuse on the main feed from the battery? Or would it be ok to just run a hot wire straight through the relay?
Olle is offline
post #7 of 14 (permalink) Old May 6th, 16, 10:26 PM
Always fuse any circuit close to its source.
post #8 of 14 (permalink) Old May 6th, 16, 11:32 PM
I have a parts store Buss AGC terminal block (six fuse) mounted next to the stock fuse box on my '67. It has circuits for stereo, torque converter clutch, alarm system, indirect lighting and a couple I can't recall. It is tapped directly off the ignition spade lug on the factory fuse lock. If I were to do it again, I'd probably have the auxiliary fuse block on a relay from battery power with the relay coil fired off the ignition terminal. That said, my headlights are not powered off the main fuse block so I'm net positive (lower) on amps on the main fuse block.
Zeke
67 Chevelle
64 Chevelle
90 Corvette ZR1
TC# 3094 ACES# 7297
zeke67 is offline
post #9 of 14 (permalink) Old May 7th, 16, 12:33 AM Thread Starter
Thanks, that's exactly what I wanted to do!
Now I need the components... bear with me, I'm a dummy when it comes to wiring and electrical stuff in general... First off, I need a fuse box. I haven't looked much further than eBay yet, but all I could find was "straight through" boxes, where each fuse has an "in" and an "out" terminal. Or in other words: A box full of inline fuses, like this one: Universal 12V 8WAY Car Truck Automotive Blade Fuse Box Holder Circuit with Cover | eBay . I would rather have one where you only connect one 12V feed wire, or do you just need to piggy back the terminals on the feed side?
Suggestions on feed wire and fuses would also be great, especially on the feed wire. How many amps and what size feed wire would you think I need?
Olle is offline
post #10 of 14 (permalink) Old May 7th, 16, 11:10 AM
You can create a bus by hooking all the terminals together on one side of the fuse block. I would use a minimum of a 10ga wire soldered to each terminal. Then use a 30a relay to power it up in the key on position and a direct feed from the battery to the fuse block. Putting a fuse on the feed wire is optional if the fuse block remains under the hood.
oldcutlass is online now
post #11 of 14 (permalink) Old May 8th, 16, 7:21 PM Thread Starter
I might put one under the hood and one inside the car, haven't decided yet but I want a fuse on it regardless.
So a 10 gauge wire would be enough to feed this?
Edit: This one looks pretty neat, one wire coming in and 6 terminals, plus LED indicators: 1 Power in 6 Way Auto Circuit Fusebox Blade Terminal Holder LED Warning 12V DC | eBay
Olle is offline
post #12 of 14 (permalink) Old May 8th, 16, 8:02 PM
What all are you going you hook up? What is the total load if you add all the items up? Answer these questions and that will tell you what size wire you need.
Use this chart:
http://www.sunforceproducts.com/Supp...ctionTable.pdf
post #13 of 14 (permalink) Old May 8th, 16, 9:09 PM Thread Starter
Use this chart:
I don't know exactly, most of the terminals will be "just in case". Right now I have ignition, light warning and tach, and will need to hook up electric choke and stereo later. I'm thinking about installing two rear window fans as well, so in short: I want a fairly good amount of spare terminals for future accessories. I'll probably figure it for 15 amp per fuse and go from there.
Olle is offline
post #14 of 14 (permalink) Old May 9th, 16, 9:51 AM
If you place it close (less than 3') to the battery then 10ga should be fine.
This Thread is more than 1291 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
