just another aggravating wiring issue, 1970 SS - Chevelle Tech
post #1 of 2 (permalink) Old May 2nd, 16, 9:18 PM Thread Starter
Roland
Send a message via AIM to forever young
ok the newest thing. i just finished getting the gas gauge working. I did all work from the top, dashboard removed. I had the gauge pod plug in and out to reach the fuel gauge. While i thought all was working well, I took the car out tonight and some strange things happened. 1st, the gas gauge goes to zero, then the blinker indicator lights go on steady. 2 minutes later all goes back to normal, minutes later, same issues, then back to normal. any clues what might be doing this? I do have 1 unterminated ground wire with a sta-con crimp that I forgot to insulate and remove is laying in that area.
"some people spend their entire life trying to make a difference, US MARINES don't have that problem". Ronald Reagan Semper Fi
forever young is offline
post #2 of 2 (permalink) Old May 2nd, 16, 10:04 PM
Re: just another aggravating wiring issue, 1970 SS
Definitely sounds like a ground problem. Might want to take a look at the sticky right above your post, sixth one down.
72 Chevelle SS conv
72ragtop is offline
This Thread is more than 1527 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
