ignition switch trouble - Chevelle Tech
post #1 of 6 (permalink) Old May 1st, 16, 2:41 PM Thread Starter
69 ss 4 speed restoring this car wasn't running when I brought it in,put in a new wiring harness for a hei dist. anyway the engine want to crank as soon as the key hit the acc. position don't know if wiring or switch tried adjusting the switch act the same thanks for your help.....
ljbryan is offline
post #2 of 6 (permalink) Old May 2nd, 16, 7:42 AM
Re: ignition switch trouble
Sounds like it's in backwards (if that's possible) since the start and acc are at either end on the switch.. Does is go into acc when you hit start?
hydro462 is offline
post #3 of 6 (permalink) Old May 2nd, 16, 9:49 AM
Hank
Like I said in your other post. You may have the wrong ignition switch in the car. Was the steering column changed to a tilt column. Tilt and non tilt columns ignition switches are different. They operate in reverse to each other.
HKalin is offline
post #4 of 6 (permalink) Old May 2nd, 16, 10:09 AM Thread Starter
want to start in acc mode in other words you don't have to push key forward a the way this is the original part and column only diff is new engine wiring harness for a hei dist
ljbryan is offline
post #5 of 6 (permalink) Old May 2nd, 16, 9:56 PM
You do know the acc position is all the way past stop and lock right? Sounds more like it's trying to start in the run position. Do you have the small wires on the starter hooked up correctly?
72 Chevelle SS conv
72ragtop is offline
post #6 of 6 (permalink) Old May 2nd, 16, 10:06 PM
Randy
Sounds like solenoid S and R terminals are wired backwards.
Randy
TC # 5401
67 Project SS Clone
pnugene is online now
This Thread is more than 1532 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
