Hei distributor with factory re-pop tach - Chevelle Tech
post #1 of 4 (permalink) Old May 1st, 16, 9:51 AM Thread Starter
Kevin
HI I am having problems with my tach it does not respond on dash gauge, put in engine wiring harness from auto wire, with up dated wiring for hei distributor. its gm distributor, and on wiring harness there is a pink and yellow wires in one clip that will fit into the tach labeled connection, does there have to be a clip into one labeled battery? also brown wire coming out of dash wiring harness does that have to clip somewheres, it originally went to coil. Thanks
hazel1 is offline
post #2 of 4 (permalink) Old May 1st, 16, 12:31 PM
Re: Hei distributor with factory re-pop tach
Pink/yellow wire goes to the "IGN" part of the coil, a tach wire should be a single tan wire. Yu can just crimp/solder a femaleterminal on it and plug it in. There is a proper black terminal if you care to locate and install. If you've got the AAW harness for an HEI, I'm surprised its not already on there.
"SSuper Dave" Palmer
A.C.E.S. #1483 TC #32 Gold
SSuper Dave is offline
post #3 of 4 (permalink) Old May 1st, 16, 2:14 PM Thread Starter
Kevin
im a little confused you said to plug the yellow pink wire into the coil? Do you mean the plug in on top of the dist where it says tach batt. and where do you plug in the tan wire that you said was the tach wire Sorry if im a little slow i didnt put the hei in just trying to learn about it. Thank you
hazel1 is offline
post #4 of 4 (permalink) Old May 2nd, 16, 10:04 AM
https://www.google.com/search?q=hei+...Q8OnP_gXicM%3A
In this pic, the tach hooks to the blank terminal.
This Thread is more than 1239 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
