Dash lights - Chevelle Tech
post #1 of 5 (permalink) Old Apr 29th, 16, 8:55 PM Thread Starter
Dash lights
Only some of my dash lights are working. I checked all the sockets and bulbs, they're all good. It's a new circuit board (72 SS gauges), no cuts or breaks.
Do all of the bulbs work off the same ground?
Is there another reason that some bulbs will light and others won't?
1972 Chevelle - 350 - TH350
Va72Chevelle is offline
post #2 of 5 (permalink) Old Apr 29th, 16, 10:28 PM
Re: Dash lights
You checked the dashboard light fuse?
peter123wallace is offline
post #3 of 5 (permalink) Old Apr 29th, 16, 10:33 PM Thread Starter
Re: Dash lights
Yes, the fuse is good. And unless I've missed something (a possibility), it would be either all or none if the fuse was an issue, correct?
post #4 of 5 (permalink) Old Apr 29th, 16, 10:38 PM
Don
Re: Dash lights
I'd be sure easy pod has a good ground, try running a new ground wire from each of the pods
Don
'72 Malibu Convertible
TC #4782
Lincoln, Ne
MidLife72 is offline
post #5 of 5 (permalink) Old Apr 29th, 16, 10:59 PM
Re: Dash lights
What I have found is that when using a new printed circuit board you must bend the tabs out slightly on the bulb sockets, so that they put more pressure on the printed circuit board. You must also be sure that the small screws that go through the printed are tight enough to make good contact with the board. Sometimes I even have to add a small star washer to get a good contact. Use a continuity tester to test to be sure you have a ground from screw to screw on the back of the cluster. Have the car battery disconnected when doing this, or you could smoke the PCB. Grounds are a common problem for these clusters having electrical problems.
RealRed70 is offline
This Thread is more than 1533 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
