Convertible top switch - Chevelle Tech
post #1 of 4 (permalink) Old Apr 29th, 16, 6:10 PM Thread Starter
Can someone please tell me where the plug coming from the switch plugs into the harness? I've been looking and don't see it and can't remember.
1972 Chevelle - 350 - TH350
Va72Chevelle is offline
post #2 of 4 (permalink) Old Apr 29th, 16, 6:28 PM
re: Convertible top switch
Steve, If you're referring to the top switch, there should be a separate harness for it. It would run along the floor with the body harness back to the motor. It connects the switch, fuse box, relay, and lift motor.
Toppless72 is offline
post #3 of 4 (permalink) Old Apr 29th, 16, 6:44 PM Thread Starter
Thanks, I found it by tracing it from the floor, it was hiding behind the windshield A/C vent.
post #4 of 4 (permalink) Old Apr 29th, 16, 8:45 PM
Re: Convertible top switch
Yes, there are a lot of things under there to get in the way making working under there difficult. At 6 foot 250 pounds, I find I'm at a disadvantage these days doing work under the dash. Normally, on any job under the dash, my first step is to remove the drivers bucket seat. Good luck with your project.
This Thread is more than 1121 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
