? about a relay - Chevelle Tech
  • 1 Post By phocksphyre
post #1 of 6 (permalink) Old Apr 23rd, 16, 9:35 PM Thread Starter
? about a relay
Just a thought - would the tach output from an MSD box work as the 'trigger' or switch to activate a relay?
'67 Elky - 496 / TH400
"Democracy is two wolves and a lamb discussing what's for dinner. Freedom is a well armed lamb contesting the vote" Benjamin Franklin
phocksphyre is offline
post #2 of 6 (permalink) Old Apr 23rd, 16, 10:04 PM
Levon
Re: ? about a relay
If the relay can read the tach signal. What are you trying to activate?
Switches, RPM Activated - Free Shipping on Orders Over $99 at Summit Racing
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #3 of 6 (permalink) Old Apr 24th, 16, 7:41 AM
Re: ? about a relay
Not likely. As its name suggests, it is a "signal", which is usually a low current AC type signal. Relays want either a solid DC voltage or a solid AC voltage, not a light duty signal.
Gary S is offline
post #4 of 6 (permalink) Old Apr 24th, 16, 8:15 AM
Re: ? about a relay
A shift light could trigger a relay.
Pioneer4x4 is offline
post #5 of 6 (permalink) Old Apr 24th, 16, 8:54 AM Thread Starter
Re: ? about a relay
Thanks for the answers. Those switches require a minimum (usually 1000rpm) or are 'window' switches. I was looking at an easy way to set up a safety shutoff for the fuel pump. I guess I am stuck with an oil pressure activated one. NBD , just a PITA to instal with header clearance and all. My EFI used a tach signal, that is why I asked.
post #6 of 6 (permalink) Old May 1st, 16, 7:21 PM Thread Starter
Re: ? about a relay
Update:
I knew somebody had to be making these. A fuel pump safety switch that operates off the engine tach signal. Just FYI to anyone else looking.
Fuel Pump Safety Switch
HandOverFist likes this.
This Thread is more than 1211 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
